Home > Technical > L320 2.7YDV6 wont start after top half rebuild |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4980 |
They are difficult to prime the fuel system. SO that will be the issue
Tue Sep 24 2024 8:58pm |
erickwan Member Since: 27 Mar 2016 Location: P Jaya Posts: 138 |
There is a Schrader bleed valve on the fuel rail on the top of the engine. Depress the nipple, turn the ignition on and off several times (10s at a time), to run the lift pump so that air is expelled. When you no longer get air bubbles, try cranking the engine over, and it should almost instantaneously start, assuming nothing else is a problem. |
Wed Sep 25 2024 2:03am |
Rozer24 Member Since: 21 Mar 2024 Location: Blackburn Posts: 5 |
Hi Andy, released off a pipe on each side and fuel comes out when cranking. Tightened them up, almost fires up with a little break cleaner in the air intake. After notice the rear two injectors have now got a pool of liquid below them(see picture) not sure where it is coming from, battery is now dead with cranking it over so cant see it coming out, it's not from the high pressure pipes as they are all dry and tightened. Any suggestions/ideas? Could this be why it doesn't start?
Sat Sep 28 2024 8:04pm |
NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 485 |
Did you change the return pipe o rings?
Sun Sep 29 2024 12:54am |
