Home > General > RRS 2.7 TDV6 2006. Dynamic Response Module (D285).
Wiggen52
Norway 2005 Range Rover Sport TDV6 HSE Galway Green
Can someone tell me where this module is located?
I have tried many hours, but …
Post #644302 Wed Sep 18 2024 4:41pm
Are you sure you have the active roll bars ?
Do you have 2 hydraulic fluid bottles ?
Post #644303 Wed Sep 18 2024 5:30pm
The control module is on the driver's side A pillar up behind the dash. Access via the footwell above the pedals. The air suspension control module is also in there. The DR module has 2 connectors. The air suspension control module has 4 connectors.
If you don't have two hydraulic reservoirs (yellow caps) in the engine bay then you don't have the dynamic response system fitted. 2012 SDV6 - it's missing a couple of cylinders
Post #644305 Wed Sep 18 2024 6:34pm
Wiggen52
Oh! I don’t have two hydraulic reservoirs in the engine bay and now I suspect the reason why my OBD2 tells me that there is no connection with the Dynamic Response Module.
I bought a used ABS module, because my old one did not work, may be this is the reason??
If this is the reason, can this be reprogrammed or do I have to by a new one?
Thank you both for your answers!
Post #644331 Fri Sep 20 2024 10:30am
