![]() | Home > General > Steering Column Universal Joint |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9051 ![]() ![]() ![]() |
The UJ is a known failure point and is a relatively easy fix. See Disco_Mikey's comments here: https://www.rrsport.co.uk/forum/topic62206...teering+uj , for example. 2012 SDV6 - it's missing a couple of cylinders
DirtyApe4x4 Member Since: 06 Jun 2020 Location: Dayton, Ohio Posts: 24 ![]() ![]() ![]() |
Easy job - relatively cheap to do and dead common failure of lower steering column u joint. 2011 Range Rover Sport GT Limited Edition/Santorini Black 5.0 Liter
Johnrrs Member Since: 16 Feb 2021 Location: Yorkshire Posts: 474 ![]() ![]() ![]() |
I’m getting mine replaced under my WD warranty at the end of the month. It’s getting done at JAS in York as well as a few more items under the warranty. Not too sure of the costs if I had to pay but I could ask the question when I drop my car off. |
Sheedy773 Member Since: 02 May 2021 Location: Castleford Posts: 27 ![]() ![]() |
Bit of grease,
That’s good news |
