Home > Maintenance & Modifications > Ace pipe help needed!
Igaffz
Hi, my 2013 RRS has a leak on the front ace pipe where it connects to the front arc bar. Garage thought it was the seal and fitted a new one but turns out it’s the pipe right where it goes into the block so they can’t fix it with a compression fitting as there’s no pipe to fix onto.
Has anyone got an old pipe I could buy? I just need the end in the picture and enough pipe to get a compression fitting on, then I can have a repair section made up. I’ve tried Facebook but I’m just getting scammers trying in on!!
Post #644227 Fri Sep 13 2024 5:01pm
Igaffz
Has anyone ever cut the pipe and connector off and had a new pice of pipe successful fitted to the connector on the end at an engineering place??? Can’t get thus section of pipe anywhere!
Post #644232 Sat Sep 14 2024 10:54am
SuperC
United Kingdom 2012 Range Rover Sport Supercharged Zermatt Silver
I’ve had all sorts of fun with my front ACE pipes. Take a look here and find the part you’re looking for. I wish you luck but I’m sure you’ll find the solution.
https://parts.jaguarlandroverclassic.com/p...5NjU2OTU./
There are a few posts on here on this subject. The full kit is not available but, check the part number LR019385. If this is the part, you can still get it.
Also, these topics might help. https://www.rrsport.co.uk/forum/topic61326.html and https://www.rrsport.co.uk/forum/topic55087.html Cheers,
Stuart.
RRS 2012 HSE 5.0 S/C Zermatt Silver.
RRS 2005 4.2 S/C First Edition Rimini Red- Gone but not forgotten
Defender 2005 TD5 XS Black - Gone
Freelander 2006 HSE Blue - Gone
Post #644347 Sun Sep 22 2024 7:32am
Igaffz
Thanks for the help, I think the pipe that’s available is the wrong one! I need the other one! I’m going to remove the end next week and see if I can have something made if possible! I’ll read you thread later, ridiculous that you can get these pipes, now these cars are getting older they really don’t make any financial sense!!!
Post #644352 Sun Sep 22 2024 1:07pm
SuperC
I hear you on that! Take a look at the threads on this. You’ll see that I fitted a “wrong” part. There seem to be several variations on these parts. The one I bought fitted perfectly. Cheers,
Stuart.
Post #644354 Sun Sep 22 2024 4:20pm
Igaffz
Has anyone got this part of a front ace pipe from an old pipe I could buy off them? I’d need it from the red line forward. It’s leaking from the pipe next to the arrow so I haven’t got any pipe to make a repair section!
Post #644474 Sun Sep 29 2024 5:47pm
