Home > General (L494) > Steering issues?
Bob lydon
Steering issues?
HI Guys
I have a strange problem with my car and was wondering if anyone had the same issue or offer some advice on what to check.
The car is a 2017 sport, 33000 miles and I have owned the car for more than 2 years.
When driving around town etc everything is fine, however at motorway speeds around 70mph the steering pulls very slightly to the left, when you correct it it pulls very slightly to the right…….i feels as though some sort of sensor is trying to correct it, is there such a sensor?.
So far I have had all of the wheels balanced, it has 22inch alloys
The 4 wheel alignment has been checked by 2 different garages, both said everything was fine and inside tolerances, the alignment paperwork showed everything in the green.
Only thing I can add is it has cheapo tyres fitted (greenlane), they were on when I bought it….do you think it may because the previous owner was too tight to fit quality tyres?.
Thanks for reading
Bob
Post #644082 Thu Sep 05 2024 4:00pm
Nick900
It sounds like lane assist is being active?
Post #644117 Fri Sep 06 2024 10:22pm
Bob lydon
Hi Nick
Thanks for the reply, what is lane assist and how do i check to see if it is on?
Bob
Post #644119 Sat Sep 07 2024 8:51am
scrumps
Bob,
https://www.ownerinfo.landrover.com/docume...0/G1899642
Scrumps Somerset - Where the apples do grow and the cider do flow!
2021 Defender 90 D250 HSE in Tasman with white roof.
24MY D300 AB - Verasine Blue - 😀
19MY SDV6 AB - Byron Blue - Gone
17MY D5 SDV6 HSE - Firenze Red - Gone
16MY SDV6 AB -Aruba Silver - Gone
13.5MY SDV6 "HSE Black" - Baltic Blue - Gone
10MY TDV8 HSE Galway Green - Gone
14MY D4 HSE in Scotia Grey - Gone
05 TD5 D90 CSW in Cairns Blue
Post #644121 Sat Sep 07 2024 11:46am
bmszabo
Netherlands 2013 Range Rover Sport 3.0 TDV6 Autobiography Orkney Grey
As far as I know (and in my RRS 2015) lane assist does not correct your driving, only gives a (tactile) warning when leaving the lane. Maybe different in 2017 model.
Post #644122 Sat Sep 07 2024 4:45pm
Nick900
Bob,
I think the 2017 does correct steering. Easiest way is assuming you have the virtual / digital dash either check in settings using the left hand steering wheel menu access to see if you have lane assist. Or look at the speedo, approximately at 7pm just off the speedo there should be 2 not quite parallel lines about 25mm long that get narrower towards the top and are dotted.
If you have this an it is active then it is quite possible the car trying to correct itself if it detects the car drifting towards the limits of the lane. The system is quite crude so when it corrects it can overcorrect and feel like its bouncing you off the limits of both sides of the lane.
Nick
Post #644140 Sun Sep 08 2024 2:14pm
