Home > General (L494) > Do L461 wheels fit on L494 |
sterling01 Member Since: 19 Apr 2015 Location: Kilmarnock Posts: 133 |
Does anyone know of the new L461(MY22+) sport wheels will fit on the L494(MY14-21)?
Sat Jul 06 2024 8:45pm |
scrumps Member Since: 01 Aug 2011 Location: Somerset Posts: 531 |
Sun Jul 07 2024 9:22am |
Great, thanks Current - 2020 Range Rover Sport P400e
Sun Jul 07 2024 11:38am |
L461 wheels DO fit on L494. I bought a set of 21" wheels from a from a 2024MY RR Sport. They were matt grey so I had them stripped back, powder coated in gloss grey and then the faces diamond cut.
Wed Sep 04 2024 7:20pm |
Thu Sep 05 2024 5:00pm |
They fit, the nuts are torqued up correctly, the car drives perfectly for the last 1,000 miles. And no, I have not told the insurance. Did you tell the insurance about all the factory optional extras that are fitted to your car? No, nobody does. Current - 2020 Range Rover Sport P400e
Thu Sep 05 2024 5:58pm |
Fri Sep 06 2024 6:37am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4971 |
The wheel nuts on a L494 may well have a taper on them the same as the L320, but it does not locate the wheel, as the wheels are spigot mounted the same as most L/R vehicles the nuts just retain the wheel on the vehicle using the flat faced rotating washer attached to the nut , provided the spigot dia. is the same and the shoulder on the nut locates in the rim snugly to prevent any rotary movement would think they should be o.k. when torqued up.
Fri Sep 06 2024 7:40am |
Thanks for the common sense Col and not the sanctimonious adenoid sounding twaddle of others. Current - 2020 Range Rover Sport P400e
Fri Sep 06 2024 7:52am |
Hi Sterling,
Fri Sep 06 2024 12:04pm |
