Home > General (L494) > P400E HV heater |
hoppy_70 Member Since: 28 Mar 2009 Location: United Kingdom Posts: 437 |
Had a search and couldn't see much about this problem, which is odd, given that a Facebook group that I'm in (for the P400e) seems to talk about little else!
Sat Apr 09 2022 6:57pm |
I’m no expert but that’s how it gets described. There’s a tsb below that says 2020 on, but it seems to affect all, including the FFRR P400e.
Sun Apr 10 2022 4:40pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8932 |
This is a LR main dealer, presumably, as it's approved used. I'd be sending some messages to LR Customer Services. It won't help you, but it might mean the next person that buys it gets a better condition vehicle. LR main dealers are absolutely terrible. They give LR a bad name and until LR gets their finger out and sorts out the network, they'll be saddled with the reputation of being expensive, unreliable, junk. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Sun Apr 10 2022 7:03pm |
Cunny678 Member Since: 08 Feb 2019 Location: Manchester Posts: 56 |
Thanks for the post. This has just happened to me and is exactly as described. Hopefully the dealer will take notice of my comments when I book it in. Luckily I bought the extended warranty |
Wed Jan 04 2023 2:52pm |
Also, another test to confirm the problem is the cabin pre heat doesn't work on the remote App. |
Wed Jan 04 2023 2:58pm |
I’d scan it and show them the code if they’re resisting. I hear if so many where they say it’s just how they are supposed to be because they know the parts are in short supply. Range Rover Sport HSE DYnamic SDV6 Velocity blue 2020 MY Range Rover sport HSE Dynamic P400e Silver Range Rover Sport 3.0 SDV6 HSE Dynamic 2016 MY Range Rover sport 3.6tdv8HSE 2007 Gone Range Rover sport 2.7tdv6SE 2005 Gone Range Rover sport 2.7tdv6SE 2007 honey Range rover Vogue 2005 4.4 - GONE and missed BMW 535d M sport 2006 - GONE not as missed BMW X5 4.4 2004 sport - GONE |
Sat Jan 07 2023 11:45pm |
New heater fitted at dealership which has resolved the issue. They say it would have cost appox £1k so the extended warranty has paid for itself almost. |
Thu Feb 09 2023 2:31pm |
KWS Member Since: 15 Jan 2008 Location: Surrey Posts: 4 |
Lots on here about HV heater problems so apologies for raising something linked to that but I haven’t been able to find a post that addresses my specific issue… I’ve recently had to have the HV battery (and wiring loom) replaced in my 2019 RRS P400e - purchased, approved used, from our LR main dealer last Summer. Thankfully it’s all been done on warranty, albeit it took 4 (winter!) months and three visits to complete. The replacement has fixed an auto start/stop fault, the car’s insistence on running the engine over EV, and part fixed its climate control heating - which has finally started working, but only on the passenger side! My issue is that the vents are still pumping out just cold air on the driver’s side, which is a misery in this weather (heated seat and steering wheel help but it’s genuinely painful around lower legs/feet). Service manager has tried fobbing me off with excuses about A/C focusing on the driver and can only recommend turning auto climate off and running only fan and high heat to try and warm the cabin! In desperation I’ve tried this but it still only slightly improves the heat coming out of the passenger vents, with driver’s side still blowing as cold as the air outside. Has anyone experienced anything similar with their climate after getting the HV battery replaced, or have any idea why one side is now trying to heat the car whilst the other is blasting out cold?.. 🥶🥶🥶 |
Sat Mar 11 2023 11:54am |
Watski Member Since: 28 Aug 2024 Location: Cheltenham Posts: 1 |
I have a RRS PHEV 2019 which has consistently had this issue. I’m on the 3rd HV heater and the problem has arisen again. No doubt the recommendation will be its 4th!!
Wed Aug 28 2024 11:57am |
flash9919 Member Since: 21 May 2024 Location: South West Posts: 3 |
I had an Evoque p300e, that went through a HV heater every year without fail…..as well as a loom, new electric motor….the list went on…I vowed never to buy another LR product…..I’m now in a used 20MY RRS 4.4 oil burner and the wife has a late d4 having done the crank in her d3!…..but at least I didn’t buy a new LR product |
Thu Aug 29 2024 7:54pm |
