Home > General > 3G Switch Off - Easy work around (important lesson learnt) |
RRT Member Since: 26 Mar 2018 Location: South Coast Posts: 251 |
This thread follows on from here:
Fri Dec 23 2022 3:57pm |
TheWojtek Member Since: 08 May 2015 Location: Poznań, Poland Posts: 737 |
Great hack!
I believe this is due to power requirements of the USB stick - it has to do both 4G and wifi simultaneously and the USB ports in the car provide just the bare minimum (500 mA) to pass USB certification. Your new source has probably around 2-5A current, so the modem is happy now. Regards etc., Wojtek --- WAS: 2006 RRS Supercharged IS: 2010 RRS TDV8 HSE |
Fri Dec 23 2022 7:09pm |
Mgs1000 Member Since: 21 Nov 2021 Location: Oxford Posts: 34 |
Thanks, this is a good workaround.
Thu Aug 01 2024 8:32am |
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1849 |
No, the 3G is a chip on a logic board somewhere and not upgradable.
Thu Aug 01 2024 10:59am |
Puslinch Member Since: 08 Jan 2017 Location: Surrey Posts: 203 |
Shortcuts in iOS is your friend for connecting BT, wifi and some creative automation hacks! 2018 Telsa MS
Thu Aug 01 2024 2:10pm |
andygts Member Since: 08 Jun 2024 Location: Yorkshire Posts: 16 |
giffgaff sim will buy you another year as they run on O2 who are apparently the last to switch off in 2025. Current
Thu Aug 01 2024 2:16pm |
Thanks for all the help on this, I think it's now sorted.
Mon Aug 05 2024 1:25pm |
Yeah, well, that didn't work. I have pretty much no phone signal at home, which is why I though it was working but I've subsequently discovered that the 4g modem won't connect to the mobile service. It creates a hot sport but with no internet connection.
Tue Aug 20 2024 7:06pm |
Did you power the USB modem from the USB port rather than from a "Cigar Lighter" USB power supply?
Tue Aug 20 2024 7:30pm |
This is just testing it on my computer. I can log on to the hotspot, then into the set up to change the API details for my Smarty SIM (Three) but the device doesn't connect to the network. |
Wed Aug 21 2024 9:16am |
I
Wed Aug 21 2024 9:19am |
I take it you are using a data device plan SIM not a phone SIM? 2023 P440e SE Dynamic on order -cancelled
Wed Aug 21 2024 12:37pm |
It's the same SIM that was in the car - which works fine, at least until they turn off 3G |
Wed Aug 21 2024 2:15pm |
"Before purchasing, check the frequency band used by your local carrier to ensure that it is compatible with your local usage." 2023 P440e SE Dynamic on order -cancelled
Wed Aug 21 2024 3:32pm |
