![]() | Home > My Range Rover Sport > Water Ingress Sport 2015 Help 🥴 Leaking |
Johnrrs Member Since: 16 Feb 2021 Location: Yorkshire Posts: 469 ![]() ![]() ![]() |
I’m assuming your car has the sunroof that moves not just the panoramic glass roof that’s fixed in place? The sunroof is quite a common place for water ingress due to the drain hole pipes corroding (or something like that). I think it’s quite an easy DIY job . Do a search on here or maybe YouTube . |
Danny1990 Member Since: 30 Sep 2018 Location: Lancashire Posts: 6 ![]() ![]() |
Yeah that’s right.
Put sunroof drain holes into the search on here. There are loads of posts about it. Could be a 5 min job if your lucky…… |
Grimble Member Since: 21 Aug 2020 Location: Staffordshire Posts: 260 ![]() ![]() |
I had the same and looked up a load of fixes here and in other places. Its not a 5 minute job and can be fiddly but worked for me.
Yeah I’m lucky I don’t have the sunroof only the fixed panoramic roof |
Should I replace the drain pipe too ? It’s the middle hole that’s corroded will this be the one ?
Don't think you need a new tube, I was able to clean out the rusty debris and re-use the original without any problem. This thread has a lot of advice:
