Home > General (L461) > L461 - issue - fuel filler cover not flush fitting. |
JDPRRSUK Member Since: 13 Apr 2023 Location: Leeds Posts: 237 |
@scrumps - did you ever get yours sorted? |
Thu Feb 08 2024 6:24am |
bimjim Member Since: 17 May 2010 Location: Hertfordshire Posts: 77 |
@JDPRRSUK That looks much better. Do you know if it's a replacement, or did they make some adjustments? |
Thu Feb 08 2024 2:23pm |
rsr Member Since: 10 Aug 2022 Location: Manchester Posts: 31 |
Mine has been in for this, I’ve been told it needs a spare that is on back order and could be months. |
Thu Feb 08 2024 10:21pm |
scrumps Member Since: 01 Aug 2011 Location: Somerset Posts: 514 |
JDPRRSUK,
Sat Feb 10 2024 1:42pm |
Looking at my flaps again today I think they've gone the other way and have actually improved a little. Still not perfect, but better than they were. All very odd. |
Sat Feb 10 2024 5:46pm |
Mine is the original. Not sure what they did but huge improvement.. |
Sun Feb 11 2024 12:33am |
McTyke Member Since: 12 Feb 2024 Location: Glasgow Posts: 2 |
Mine was at the dealer in Motherwell yesterday to sort out the squeaking roof lining around rear view mirror (which they sorted) I pointed out the two filler flaps alignment issues to the techy chap who said mine were better than most. He said he could have a go with a heat gun but it could make it worse. Decided to leave it - its not that bad - so far (collected 23 December and done 1600 miles) 2024 Firenza Red P460e Dynamic SE |
Wed Feb 14 2024 4:42pm |
JDPRRSUK,
Wed Feb 14 2024 5:58pm |
Atlanticjon Member Since: 22 Apr 2015 Location: Coleraine Posts: 42 |
Picked mine up and thanks to the forum looked for the fuel flap alignment, and it was slightly askew. Technician had a go at adjusting it and improved the line up. But they have ordered a new mechanism…. |
Sat Feb 24 2024 12:55pm |
Thu Jul 18 2024 12:28pm |
Thanks for update @scrumps. Mine is still okay but have noticed it is not quite as flush as when they first fixed it. |
Sat Jul 20 2024 8:21am |
Wed Aug 07 2024 12:39pm |
RabJ Member Since: 06 May 2024 Location: Ballymena Posts: 16 |
Mine was ok when pickked it up, but now three momthes later its starting to protrude a bit along the bottom edge. |
Mon Aug 12 2024 9:29pm |
