![]() | Home > Technical > Crankshaft sensor replaced by mechanic with small hands. |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4446 ![]() ![]() ![]() |
Piece of cake with the front diff out |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9048 ![]() ![]() ![]() |
How involved is removing the front diff, D_M? Less than the gearbox, presumably. 2012 SDV6 - it's missing a couple of cylinders
Out and in in 3-4 hours, and much more room around the area in which to work |
Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 438 ![]() ![]() ![]() |
Sorry dont get the diff out solution to the crankshaft sensor.
I've done them before. You booked into a garage to have it done
Sure you do micky but how does removing the diff get you more access behind the turbo? Always listen to old people or when they die you will live on in ignorance.
I think its Disco Micky as in taking the Micky or as we say up north taking the |
Wow, your pleasant |
Ken 153 Member Since: 02 Sep 2021 Location: Sheffield Posts: 189 ![]() ![]() ![]() |
