![]() | Home > General (L494) > Clunky suspension |
Grimble Member Since: 21 Aug 2020 Location: Staffordshire Posts: 260 ![]() ![]() |
L494 2014 3.0 HSE
2 RRS Member Since: 04 Sep 2016 Location: Shropshire Posts: 160 ![]() ![]() ![]() |
Front anti roll bar bushes most likely, fairly cheap and easy DIY job to fit. |
T Member Since: 18 Feb 2024 Location: Isle of Wight Posts: 70 ![]() ![]() ![]() |
It's an earlier model than yours, but this gives you the idea:
Thanks for the reply guys, replacement bushes, OEM or aftermarket? RRS HSE Dynamic SDV6 2014
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1181 ![]() ![]() ![]() |
OEM |
Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 422 ![]() ![]() ![]() |
Nil carbarundum illigitumi
Thanks for the video, I'll probably do all 4. I think the noise is at the front, but hard to be 100% sure.
Punkawallah Member Since: 04 Sep 2018 Location: Salisbury Posts: 159 ![]() ![]() ![]() |
I had exactly the same thing on my old 2014 dynamic and it was actually play in the ACE (Dynamic cornering thing) valve block. It's a known problem and is solved by fitting a later/improved valve block which I bought off ebay for around £400 I think. 2014 L494 V8 s/c Autobiography Dynamic |
I'm struggling to find the correct bushes for the front anti roll bar. A lot of sites are quoting a chassis number which bears no relation to mine, so I'm confused as to the correct item.
RRS4ED Member Since: 05 Feb 2021 Location: Yorkshire Posts: 42 ![]() ![]() |
I bought below and lasted 25k miles:
Thanks for the reply, the vast majority of my (admittedly low) miles are on the motorway, I've had the car for about 25k miles, so its probably time they were changed, as most of the advice on this post suggests.
Well i followed the official technical document and it took me a day and half and you do need 2nd person unless you can have a jack similar to transmision one. The Hydraulic ARB unit is really heavy and needed 2nd person to help me.
Saw on a video of the job on an early model sport, that the bushes need to be greased. On the video, it looked like a small packet of grease was included. The bushes I ordered came with nothing, so my question is, should the bushes be greased or not and if so with what? RRS HSE Dynamic SDV6 2014
The service manual advices against lubricating the bushes, i just done mine again with using dielectric grease. |
