Home > General (L494) > Anyone swapped rear hub bushes...
Karlp606
Started getting a small squeak/creak on turning right , usually over 20mph around roundabouts, seems to be coming from the rear drivers side of the car, no knocks or anything like that going over bumps etc just a odd squeak/creak now again when the car is leaning around a corner, presume these are the rear hub bushes that will need swapping out or possibly dried out - would it be worth a dowse in some silicone spray and are they easily accessible without ramps?
Post #642460 Thu Jun 06 2024 1:27pm
Karlp606
Any help be appreciated guys... and can you swap the bushes with no post lift, can you do it under the vehicle with it in extended mode?
Post #643123 Mon Jul 08 2024 1:31pm
