Home > Technical > HELP Crankshaft sensor location ...2.7 l |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4925 |
You need to get under the car I think
Fri Jul 05 2024 12:55pm |
Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 410 |
In the prescribed areas in the video I can find nothing ..have it all stripped out below and on LHS ..if I could find a wire to follow it would help.
Fri Jul 05 2024 1:05pm |
There was a pic by cmb on D3 showing the 3 pin connector |
Fri Jul 05 2024 5:46pm |
Had a reply from No Expert in the US who tells me its behind the support plate ( 2.7l) for the turbo near the exhaust to turbo flange in fact the clip securing the connector is attached to that bracket.
Sat Jul 06 2024 6:06am |
Do some research on Disco3 and the link I gave you.
Sat Jul 06 2024 7:07am |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 |
The 2.7 had one turbo, the 3.0 had twin turbo's with associated plumbing changes which may be yor problem., |
Sat Jul 06 2024 7:53am |
