Home > General > RRs 3.0
Inch’s
RRs 3.0
Hi got a 2009 sport I’m trying to find the starter relay would anyone be able to point me in the right direction ? Having issues starting basically went to it yesterday tried to start it and nothing ! So called out the AA they suspect it was the starter motor so I changed this today and still nothing so went and got a new battery thinking it might be the next issue again nothing so now I’m things the starter relay ! But can’t seem to locate where it is. Has someone had this issue before ? Or can help on this matter thanks.
Post #643071 Fri Jul 05 2024 8:04pm
NoExpert
It’s not R6 under the hood?
Ground strap is okay? Check for ground and live at the starter. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #643074 Fri Jul 05 2024 8:49pm
Inch’s
Worth a try just looked at the diagram on the back of the fuse box R18 says SM ! Starter motor ?
Post #643075 Fri Jul 05 2024 8:54pm
Inch’s
Gonna try ground strap in the morning as it’s pouring down just tried SM relay and R6 both working fine tested them they both click away.
Post #643076 Fri Jul 05 2024 9:28pm
With the car in park.
Try bypassing the relay connections and see if the starter works. Go from there.
If it starts, sometimes the relay connections under the fusebox get corroded
Post #643078 Sat Jul 06 2024 5:05am
Inch’s
Thanks Andy definitely will give this a go
Post #643080 Sat Jul 06 2024 7:43am
Inch’s
No Reply put a lead on it and fired up bloody thing
Post #643084 Sat Jul 06 2024 10:01am
Started with a jump lead to engine metal work? well that is good news
Post #643085 Sat Jul 06 2024 10:08am
NoExpert
Ground strap is in front of the right front strut tower behind the wheel arch.
Post #643092 Sat Jul 06 2024 5:45pm
Ian335
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Orkney Grey
This was mine. Car wouldn’t start. Ground strap being chafed by plastic wheel arch lining.
Post #643143 Tue Jul 09 2024 1:09pm
