![]() | Home > Technical > Aircon |
JohnBlueSport Member Since: 28 Jun 2019 Location: ayrshire Scoltland Posts: 25 ![]() ![]() ![]() |
Hi, Is it possible to remove the aircon pump and pipe work ,and use a shorter fan belt . Aircon not working to costly to replace parts , been quoted nearly £1500 Thanks |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4887 ![]() ![]() ![]() |
have they told you the compressor must be removed ? |
Yeah need replaced, along with condenser, before re gased, parts plus labor and vat half the value of the car, |
Can't find the quote, but they must be quoting for new land rover parts, think the pump was nearly £600 including vat, and regas was £70. Is there anyway you can check the pump myself, incase they're at it , |
I think you can just leave the faulty compressor on there unless it’s making a noise |
