Home > In Car Electronics > Brake light issue
Paul_selby
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Fuji White
Brake light issue
Morning all. 2013 RRS, LED rear light clusters. The o/s/r brake light not working, n/s/r does and does when plugged into the o/s/r plug. Looking to splice into the n/s/r cable and run a connection. Does anyone know off hand which cable is the live for the brake light ? TIA
Post #642990 Wed Jul 03 2024 6:23am
Green/Purple coloured wire, quick look at wiring diagram looks like Pin No. 1 in the plug.
Post #642991 Wed Jul 03 2024 7:38am
Paul_selby
Thumbs Up Thanks a lot mate, saved me a bit of time with the multimeter
Post #642994 Wed Jul 03 2024 9:00am
If the n/s/r works when plugged in to the o/s/r plug but the o/s/r doesn't, doesn't that point to a fault within the light unit itself? How will splicing help? Surely you need to get in to the o/s/r unit to repair it or replace the unit? 2012 SDV6 - it's missing a couple of cylinders
Post #643006 Wed Jul 03 2024 11:32am
