Home > General > Replacement a/c condenser and drier 3.6 TDV8
JonnyCJ
Turns out my condenser needs replacing. The official LR ones are very expensive (£664) however I see the Nissens versions at around £110 with drier on eBay and other suppliers much cheaper than LR.
Seems they’re a common part number across a lot of the LR range ?
Thoughts on what to buy appreciated !
Post #642876 Thu Jun 27 2024 10:36am
Yes, go aftermarket for that component.
Yeah, Nissans is fine
Post #642877 Thu Jun 27 2024 11:43am
Jellis39
Had an aftermarket on ours last year and it’s been fine.
Post #642882 Thu Jun 27 2024 4:07pm
JonnyCJ
What’s the labour time involved in installation ? I take it it’s best left to a specialist, although if it’s diy I do enjoy a small project.
Post #642883 Thu Jun 27 2024 5:51pm
NoExpert
Definitely go Nissens.
As for difficulty, I think you could do it with the bumper and rebar off pretty easy. The cooling package is nearly the same as my 3.0. I’d think it’s a 4-6 hour job to do depending on skill level. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #642887 Thu Jun 27 2024 8:01pm
DIY !
2 ways.
1). Remove bumper. Remove crash structure. (Torx bolts can be seized)
Or
2) drain coolant. Remove fan. Remove both rads. Change condenser.
Post #642888 Thu Jun 27 2024 8:03pm
JonnyCJ
Thanks NoExpert and Andy. Will see what the garage come back with cost wise. They’re doing body off turbo changes etc all time, so no doubt have condensers down to a fine art.
Will see if YouTube can give me some guidance.
Also need a new torque converter shaft seal, which I’m definitely not attempting !
Post #642891 Thu Jun 27 2024 9:02pm
JonnyCJ
Been watching a very useful video on replacing the rad and condenser for a RRS 2005-2013. All looks pretty doable. The only thing fazing me is the fan removal, which looks like I'll need special tools to get off.
Are they a "thing" or can I use spanners ? Happy to spend £20 or so on the right tools to save paying a mechanic to do a job I can do.
Edit - just found the tools on Powerful. £40 which is an expensive pair of tools for single use.
If I go the bumper off and slam panel off route, I take it it's a much easier route to success - seized bolts aside ?
Nissens condenser ordered - £100 delivered off ebay.
Post #642905 Fri Jun 28 2024 1:10pm
If the fans not been off recently they can be a real pain and time consuming.
I couldn’t remember if you had already removed the bumper before.
You need to check, you may have a larger intercooler. Or other rads in the way. But even so…
Post #642908 Fri Jun 28 2024 1:38pm
JonnyCJ
Front bumper off doesn’t worry me, I had the rear off recently to paint the parking sensors. From what I’ve seen it’s a case of moving the top of the rad forward a bit - hence undoing top rad hoses, unclippimg the cooler pipes in front of the condenser, undoing the condenser block (with the seals replaced on reinstall) and popping it out ?
There’s a couple of double threaded bolts with no head in the kit, as well as a scroll pin. Not sure where they go.
Post #642909 Fri Jun 28 2024 1:44pm
Usually the coolant rad is the main structure.
The AC condenser hangs off the coolant rad. So two bolts. Lift up out the slots.
As you say, the pipe joint and seals.
From what i remember in mine.
Had to bend the pipes slightly for good alignment.
bit like this disco
https://www.disco3.co.uk/forum/air-con-condenser-98740.html
Post #642912 Fri Jun 28 2024 4:09pm
JonnyCJ
Thanks Andy - makes for some enjoyable bed time reading !
Really appreciate all your responses on here. Makes the forum a very successful place.
Post #642914 Fri Jun 28 2024 5:29pm
gogsy1956
Did mine a couple of years ago using a Nissens condenser,, wasn't in a race to do it,, fiddly rather than difficult. I'm sure there are pics in my gallery but basically grill off, lights off and bumper off, loosen off slam panel and pull forward, this allows wiggle room to get the condenser out as it is inbetween a couple of others. There are a couple of hidden fasteners that are awkward to spot. A couple of screws either side in the wheel arches that secure to the slam panel,,,, taking these out allows the slam panel to be moved further forward. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #642916 Fri Jun 28 2024 6:36pm
JonnyCJ
Thanks Gogsy - yep, saw your thread in the history and it’s one of the things that’s given me the confidence to try it myself, so very much appreciate you posting up your experience.
Post #642917 Fri Jun 28 2024 6:44pm
JonnyCJ
Condenser arriving tomorrow apparently, so getting all geared up to sort the change over at the weekend.
A few questions for the skilled and able on here if I may...
1.) From what I've read, the T40 bolts holding the slam panel on are prone to snapping. Does anyone have a part nr or size, so that I can have some on standby for when that happens to me ?
2.) The various guides I've read say to remove the front bumper. Mine is a MY2010 3.6 TDV8, however, Disco Mikey's excellent Disco 3 writeup has the Disco bumper still in place. Is it necessary to remove the bumper on a RRS 2010 ?
3.) I was also going to order an long extension to get to the bottom bolts that hold the rad in place. Is it necessary to undo these to move the radiator in towards the engine and if so, can they just be loosened or do they need to come out ?
Will report back with any tips I come across.
Many thanks
Post #642960 Mon Jul 01 2024 11:28am
