Home > Maintenance & Modifications > Height suspension / sensor issue - can't calibrate |
csa241 Member Since: 25 Jun 2024 Location: Sydney Posts: 2 |
Hi guys - need some help diagnosing my issues with my L320 2011 TDv6.
Tue Jun 25 2024 10:09am |
erickwan Member Since: 27 Mar 2016 Location: P Jaya Posts: 131 |
Spend some precious $$$'s and get yourself a proper diagnostic tool like a Gap II. What you see at the sensor bears no relation to what the suspension ECU sees. |
Wed Jun 26 2024 11:14pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4939 |
Those height measurement are well outside the factory standard ride heights for the sport, 461mm front and 465mm rear give or take a few mil.
Wed Jun 26 2024 11:29pm |
peterjj Member Since: 15 Mar 2017 Location: Canberra Posts: 46 |
like what i think erikwan said, the numbers on the diag tool most likely don't relate to real life measurements. Measure actual values, the adjust a little bit on the diag tool and see what happens, then repeat repeat until the actual hub to arch measurements are all correct. Pete
Thu Jun 27 2024 12:11am |
What I meant is what you measure at the sensor means nothing. What voltages the suspension ECU sees is more relevant. |
Thu Jun 27 2024 8:56am |
