Home > General > Smoke test / pressure zero
Toonraider
United Kingdom 2008 Range Rover Sport TDV6 HST Stornoway Grey
Hi all.
Trying to cure a suspected intake leak on my 2.7 sport.
I'm getting a noise like..ssshhhh ssshhhh at about 25 to 30 and 1800 to 2000 rpms.
Engine seems fine, gears all fine,no black smoke.
So, I tried a smoke test and it duly escaped from the open oil cap neck, no where else, that I can see. Anyhow, this set up has a pressure gauge that allows just air to be pushed through the system. But when doing so, no pressure builds on the gauge at all. Does that definitely mean there is a leak somewhere or is the air leaving through an exhaust port etc.
Any help and advice greatly appreciated.
Post #642478 Fri Jun 07 2024 9:21pm
Lrstaylor
United Kingdom 2006 Range Rover Sport Supercharged Bali Blue
You won't build up pressure in the engine. What smoke tester are you using??
Mine has a gauge on it but that's only to show I'm pushing smoke out of the machine
Post #642483 Sat Jun 08 2024 8:09am
Pistnbroke
how to do smoke test is here..
 Always listen to old people or when they die you will live on in ignorance.
Post #642485 Sat Jun 08 2024 8:21am
Toonraider
This one.
Post #642486 Sat Jun 08 2024 8:41am
Toonraider
Post #642487 Sat Jun 08 2024 8:42am
Pistnbroke
mispost Always listen to old people or when they die you will live on in ignorance.
Post #642488 Sat Jun 08 2024 8:42am
Toonraider
Been away a while, but forgot to ad that smoke does emit from the elbow of the intake pipe that leads down to the turbo. There's a rubber grommet or gasket on the end. I've tried searching for the part number, but no luck. Anyone know the part I mean by chance ?
Post #642860 Wed Jun 26 2024 5:14pm
peterjj
Australia
should find the part number here somewhere https://parts.jaguarlandroverclassic.com/p...and-rover/ Pete
2008 L320 TDV8
2022 Hilux Rugged-X
Post #642868 Thu Jun 27 2024 12:04am
Toonraider
Hi, thanks for that but I'd looked at that one and it didn't show. It's a rubber seal that sits in between the two pipes to the right on the picture near h2 bolt. Approx 80mm round and 50mm deep with ridges to help keep it in place. Strange that it's not listed.
Post #642872 Thu Jun 27 2024 8:27am
