Home > Technical > P033660 2.7 2009 Advice crank sensor
Pistnbroke
Runs fine for 20 miles or 2 miles then limps/stops .
Yes crankshaft sensor but I understand you can change the sensor with a lot of hassle from behind the LH front wheel by the turbo ...well a lot less hassle than taking the gearbox out..
Any thoughts Always listen to old people or when they die you will live on in ignorance.
Post #642838 Tue Jun 25 2024 4:27pm
NoExpert
It’s there:
Behind all this:
However this is on a 3.0, but it’s very similar to a 2.7 on this side. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #642851 Wed Jun 26 2024 7:23am
Pistnbroke
Helpful. I have a video on how to do it ..involves taking upper wishbone off and some heat shields but if its possible must be easier than taking off the gearbox ..TFB and exhaust etc. Of course may be a problem with the connector ..I should be so lucky ! Always listen to old people or when they die you will live on in ignorance.
Post #642853 Wed Jun 26 2024 8:10am
