Home > General (L461) > P440e - Wind noise |
bimjim Member Since: 17 May 2010 Location: Hertfordshire Posts: 88 |
I've had the same problem and had the update JLRTB02120v5 applied last week. This has made only a marginal difference I would say.
Mon Jun 24 2024 3:47pm |
Skyline Member Since: 01 Jun 2022 Location: Hertfordshire Posts: 97 |
I’ll keep you posted on my next steps.
Mon Jun 24 2024 4:32pm |
Which dealer are you using?
Mon Jun 24 2024 5:29pm |
I don’t trust Grange Hatfield even though it’s my nearest dealer.
Mon Jun 24 2024 7:44pm |
My thoughts on Grange match yours. They’re also my nearest dealer, which makes it particularly annoying. 2023 P440e Dynamic SE |
Mon Jun 24 2024 9:40pm |
Beadles will look after you. Please mention my referral and ask for Ella MY23, 3.0 P440e PHEV AB, Carparthian Grey, Deep Garnett interior
Tue Jun 25 2024 5:39am |
Jjvd21 Member Since: 20 Dec 2011 Location: Chicago Posts: 242 |
Any L461 forum has posts and posts about the wind noise and subsequent potential fixes. How is it possible LR do 1,000 KM's of testing on these new models and things like wind noise aren't picked up? Test drivers must be wearing headphones?? 2020 SVR / R.I.P. 2019 SVR / 2016 D4 Landmark / 2005 D3 HSE |
Wed Jun 26 2024 10:05pm |
PauloAmore Member Since: 27 Jan 2007 Location: Bonnie Scotland Posts: 1292 |
Same problem on mine...
Tue Jul 09 2024 1:54pm |
I’ve added some packing foam behind the speaker trim next to the triangular window. I think this has helped a bit, although I need to do some more miles to be sure.
Wed Jul 10 2024 6:08pm |
JDPRRSUK Member Since: 13 Apr 2023 Location: Leeds Posts: 275 |
They do - there is a detailed bulletin with the fix for dealers. |
Wed Jul 10 2024 9:45pm |
I know, as per my reply further up the thread, I’ve had the latest official bulletin work done but that didn’t resolve the problem. 2023 P440e Dynamic SE |
Thu Jul 11 2024 7:20am |
My p440E back from the dealer - didn't need a new windscreen as the original one didn't crack when removed - they did a smoke test beforehand to conclude the windscreen was at fault and the area in front of the drivers side lower end corner was the culprit - I saw pics of the seal that had totally broken away between the bodywork and glass. Seal was re-applied and old windscreen replaced - noise levels much improved.
Mon Jul 22 2024 3:08pm |
That’s interesting, thanks for sharing. That’s the first time I’ve read about the seal around the windscreen possibly being the culprit. 2023 P440e Dynamic SE |
Tue Jul 30 2024 1:50pm |
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1849 |
Very common on D5's built in Slovakia, not heard of it before on a Sport. 2023 P440e SE Dynamic on order -cancelled
Tue Jul 30 2024 3:16pm |
