Home > My Range Rover Sport > Sasha’s Pre Production Range Rover Sport L320 |
SashaGrace Member Since: 24 Jan 2024 Location: Rhuddlan Posts: 23 |
Fuel tank cradle and prop centre bearing? Completed it mate. I’m so glad the tank didn’t fall out with £130 worth of diesel in it on the Motorway bringing it home 😆 Centre bearing WAS NOT worth it, such a faff of a job, if you are needing to do this, get a whole prop 😅. MoT retest on Wednesday and it’s golden for 12 months 🙌
Sat Mar 09 2024 10:52pm |
Lrstaylor Member Since: 10 Mar 2022 Location: Kent Posts: 331 |
Nice 1 |
Sun Mar 10 2024 5:46pm |
Thanks, it has its access height attitude on today ready to go! Also, not me being totally oblivious to the missing front towing eye cover and only just noticing and discovering how expensive it is!!! It’s payday on Friday so to celebrate its MoT pass it can look good from at least one angle with a fresh pair of foglight bezels, a towing eye cover and a fresh set of letters so everyone it clear that it’s a Range Rover.
Sun Mar 10 2024 6:00pm |
Latest parts haul; quite confident the RRS hasn’t seen any new genuine service parts for some time. Call me old fashioned but I always use OE filters on the cars, WZU will be no exception.
Mon Mar 25 2024 12:52pm |
Long time no update, but I have been busy.
Sat Apr 20 2024 10:19pm |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1251 |
It does look good and the devil is in the detail. It's funny how these things make a big difference. 2006 2.7 TDV6 HSE in Cairns Blue. |
Sun Apr 21 2024 6:08am |
As my little friend is showing signs of recovery I decided to get out and complete some of the engine bay prep post the service. I used 5w40 ACEA B3/B4 oil in it as the famous 2.7 low oil pressure and slight death rattle on start up were present with the 5w30. It never has a lingering oil pressure light now and it is the recommended oil by PSA for the 2.7 Lion in their cars from new so I feel good. I know some will say ‘stick to the 5w30 only, it’s what LR say etc etc’ and that’s fine if it works for you, but the 5w40 makes more sense for me. It’ll be on a 3000 mile interval now and it’s a 19 year old 139k mile engine, not new anymore.
Sun Apr 21 2024 10:47pm |
Thewilbury Member Since: 24 Jul 2021 Location: Dublin Posts: 12 |
LOVING your work so far! well done!! |
Fri Jun 14 2024 10:10pm |
Satisfying isn't it |
Sat Jun 15 2024 5:23pm |
Quick update, the car has been to a couple of shows with the CVC Register and will be at LRO Belvoir in September if anyone wants to come and say Hi. I’ve been plugging away with parts searching and I finally found another 734 Giverny Green car being broken up and I bagged a pair of doors, bonnet and a few other bits to replace my panels that were honestly too far gone.
Sun Aug 11 2024 10:58am |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8922 |
Have you considered having the gearbox flushed? The standard drain and refill method doesn't get all of the old oil out. I'd be tempted to flush it and then change the sump and filter if you're going that route. Uses a bit more oil, of course, but then you'll have a full fill of new oil. 2012 SDV6 - it's missing a couple of cylinders
Sun Aug 11 2024 11:22am |
Great update |
Sun Aug 11 2024 11:23am |
Yes I will flush it with how bad this is and then likely do the oil again in the near future as I’m sure it’s original 20 year old fluid. There are signs of love in this car, I think it was mechanically maintained up till about 2020 and when it went to Bristol it lost any trace of love! |
Sun Aug 11 2024 12:17pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4376 |
Steel sumps are notorious for leaking
Sun Aug 11 2024 7:06pm |
