![]() | Home > General > Are my wheels correct ? |
Looks like a L322 Range Rover wheel, not an L320 RRS. If so it’s probably 20x8.5 with a 57mm offset. Stock wheels on the L320 RRS should be 20x9.5 with a 53mm offset. If you want to get closer to the correct diameter you should look for 255/45R20 tires. The average recommended max tire width on an 8.5” wide wheel is 255 so you’re rather limited by this. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4452 ![]() ![]() ![]() |
They are L322 Westminster wheels
JonnyCJ Member Since: 25 Apr 2011 Location: Wirral Posts: 430 ![]() ![]() |
Thanks both - really helpful. Now I have to decide if I want to stick with them, or go original…
Following on from this - I can get some mint style 520 (10 spoke V) wheels locally for a decent price. I think they were standard on an L494 ?
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9051 ![]() ![]() ![]() |
Simple answer: no. Long answer: no, they're not even RRS rims. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5066 ![]() ![]() ![]() |
I think you may find the 520 style rim is still a 8.5J rim, but happy to stand to be corrected.
520 style is 20x8.5 with an ET47 offset.
So that pretty much rules out using 520 10 spoke style with the Brembos as the offset is too “in” to the hub ? |
So crunching the numbers…. The 20” Westminster wheels which I have are 8.5J with an ET of 58 Stock 20” L320 rims are 9.5J with an ET of 53 I used a very handy wheel offset calculator to work out that my wheels sit in by 17.5mm at the outside edge, compared to the stock wheels and 7.5mm at the inner edge. https://jr-wheels.com/et-calculator Using a 20mm spacer, I can pretty much replicate the stock stance from the outside (actually sticks out 2.5mm more), although the inner edge is just over an inch further away from the suspension, but does allow me to use the Brembos. Saves having to change wheels and tyres and means I can stick with the wheels I like. |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 782 ![]() ![]() ![]() |
Probably worth just checking with your insurance company that they are happy with a) spacers, and b) wheels that were never specified for the L320 (albeit they are gen LR and no doubt have the correct weight loading).
Good points - thanks ! |
Looking at interesting options, has anyone fitted 5007 L494 style on an L320 ?
Actually, they probably will fit as the L494 and L320 with six piston Brembos use the same calipers and rotors. I would definitely test fit to confirm though. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory Born and raised in So Cal. Moved to the UK in 2018 for a few years. Now in Poland and looking at moving back to the UK. |
The 5007 is a 21" rim and will certainly fit over the 6 pot brembo's, as I ran them on my S/C for a short while before I fitted a set 21" SVR rims. Have you actually the six pot or 4 pot calipers as the 4 pot are quite smaller anyway although the damper block sticks out from the side a little way.
