Home > Maintenance & Modifications > Please tell me this is not the dreaded timing chain! |
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1158 |
Please tell me this is not the dreaded timing chain? 😕
Sun May 26 2024 3:37pm |
a video with the bonnet open: https://youtube.com/shorts/7-JDLSxK7bQ --
Mon May 27 2024 8:30am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4938 |
Bit more legible if viewed enlarged in "My Gallery"
Mon May 27 2024 9:17am |
Cheers Col, so you think it's the Supercharger coupler?
Mon May 27 2024 9:28am |
Can't really answer that, only remember reading the tsb a while back so thought it may be a possibility, little bit of work but might be worth removeing the s/c belt and run it up to see if noise goes away first before start ripping the engine apart.
Mon May 27 2024 9:37am |
Update: a video of the supercharger being rotated by hand https://new.reddit.com/r/rangeroversport/c...replacing/
Mon Jun 03 2024 11:00am |
from superchargersonline, fml
Mon Jun 03 2024 10:41pm |
Several firm do advertise a upgraded one piece coupling for the TVS 1900 S/C which does away with the torsion spring which I believe is the main problem with the o.e. coupling failing, it might be advisable to strip it out first as you may find the shaft and bearings worn as well as the coupler, in that case you may be best ordering a snout o/haul kit.
Tue Jun 04 2024 12:04am |
Yeah, after a long chat with the mech, we are going to order one of these:
https://powerhouse.uk/supercharger-parts-r...uild-kits/ -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport Supercharged V8 HSE Dynamic Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Tue Jun 04 2024 8:08am |
^ yeah, I've heard about this as well.
Tue Jun 04 2024 4:42pm |
Hmm, apparently this is not a good idea, as @Rayodunne said:
Wed Jun 05 2024 11:26am |
rayodunne Member Since: 17 May 2018 Location: Sudbury Posts: 36 |
Your original sprung one lasted almost 9 years, just use an OEM one. lol 2009 Range Rover Sport Supercharged |
Wed Jun 05 2024 1:34pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4891 |
I guess you maybe able to get a OEM one from Eaton ? |
Wed Jun 05 2024 1:50pm |
We can get the OEM ones from LR, not a problem at all. --
Wed Jun 05 2024 3:33pm |
