![]() | Home > Maintenance & Modifications > Suspension Fluid in France |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5044 ![]() ![]() ![]() |
Could see if you can find some Ravenol SSF or Texaco cold climate p/s oil or equivalent, Personally I don't think I would top it up with anything like Dextron III p/s oil.
mab25715 Member Since: 26 Feb 2017 Location: County Durham Posts: 8 ![]() ![]() |
I am unable to get hold of anything like that here, I'm hoping someone knows of a simpler alternative until I get back to the UK |
JonnyCJ Member Since: 25 Apr 2011 Location: Wirral Posts: 428 ![]() ![]() |
Can Amazon not deliver it to you ? |
Yes but not until 31st may |
Can I use power steering fluid? |
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1857 ![]() ![]() |
Have you done a Google advanced search and selected France as the country for results? 2023 P440e SE Dynamic on order -cancelled
Yes I have tried every avenue |
83series3 Member Since: 19 Sep 2021 Location: South East Kent Posts: 50 ![]() ![]() ![]() |
is an alternative to pull one of the wiring clips from the valve block, to force an error and stop the dynamic response from operating? A long shot, but maybe worth a try ....
I think the problem is even if you disable the system from working by disconnecting the wires, the pump will still be running, so depending on how much oil has been lost it could still damage the pump if run dry or starved of oil.
