![]() | Home > General (L461) > Ghost 2 Pro vs Starline i96 immobiliser MY2024 |
scrumps Member Since: 01 Aug 2011 Location: Somerset Posts: 554 ![]() ![]() |
skilachi Member Since: 31 Oct 2013 Location: London Posts: 55 ![]() |
Hi @scrumps, thanks for the info.
Sorry, i meant when you turn on Guardian mode, all remote features are disabled. I also like the idea of pairing with the phone so i don't have to use PIN code.
JDPRRSUK Member Since: 13 Apr 2023 Location: Leeds Posts: 295 ![]() ![]() ![]() |
You might want to check what the dealer says about affect on warranty. I was told could affect SOTA and warranty if any electrical issues cropped up. |
Went for the Ghost 2 with ADR tags and the call alert feature . It is fitted to cut off the engine when the gear is selected without the Pin code sequence entered and will get a phone call alert to notify me as well.
@scrumps decided not to use the Tags anymore and kept them away from the keys....infact 10metres away from the house . Only using the Ghost app on the phone or at times the Pin sequence. |
