Home > Technical > Battery dead and nothing working now no lights no centralloc
chamara
Hi All,
Sorry i need urgent help, i left for 2 weeks and my new Range Rover Sport 17 plate L494 compeltely drained its battery, My mrs tried to start it twice and it was left with all the lights ON (even though lights are set to off) it was showing the Day time running lights.
I didnt have someone to jump start but i had a trickle charger so i put it to charge, but before doing that i removed the negative terminal and reconnected (the main battery) that resolved the lights issue so lights were then off. But nothing was on any screen including ignition (its completely looks flat)
Now after little while of trickle charging( 3 hours) i can see the brake lights are back up. I am worried having these lights drains the battery as much as the trickle charger charges it.
Can you please guide me for the next steps I can do for this. Thanks a lot in advance.
Post #641550 Sat Apr 27 2024 12:59pm
JonnyCJ
You’ll need to charge it for a good 12 hours. Leave everything off, both battery terminals connected and have a beer whilst the charger does its thing.
Alternatively, get a jump start and drive it for a couple of hours. Flat batteries can give all sorts of scary results, which in reality are nothing to worry about.
Post #641552 Sat Apr 27 2024 1:15pm
chamara
Thanks Johnny, for the speedy response, do you think if ii get a jump start kit from Halfords help?
Post #641553 Sat Apr 27 2024 1:17pm
JonnyCJ
For peace of mind get a Noco battery pack from Amazon. Amazing bits of kit and you can keep it in the car. Probably around £80-£100 depending on sales etc.
Trickle charge overnight is your best bet and that’ll give the Noco time to arrive.
The car will be fine Very Happy
Post #641554 Sat Apr 27 2024 1:24pm
karlos01
getting a jump kit might help but if battery is right flat it might not be enough to start it
as suggested get a friend to jump it off a running car as it might need a good few minutes to put some charge back in the battery
Post #641555 Sat Apr 27 2024 1:26pm
chamara
Thanks its already on the Noco Genius 5, my worry is the brake lights are on. Hopefully its enough to push through even with the lights are on
Post #641556 Sat Apr 27 2024 1:26pm
karlos01
you might have a sticky brake switch it is accessible to disconnect the switch under the pedal while it on charge
Post #641557 Sat Apr 27 2024 1:28pm
chamara
how to do that ? do you have a picture ?
Post #641558 Sat Apr 27 2024 1:32pm
karlos01
sorry not for a 17 plate as mine is a 2006 sport
if you got a manual you could look up the fuse and maybe pull that out
Post #641559 Sat Apr 27 2024 1:35pm
Johnrrs
United Kingdom 2013 Range Rover Sport 3.0 TDV6 Autobiography Zambezi Silver
My battery went flat a few month ago and all sorts of weird things were happening and thought it was something more sinister. Once the car was charged up (overnight) the car was normal thank god. It turned out the battery was on its last legs and me opening doors, boot, bonnet etc when I washed it killed the almost dead anyway battery. My battery was still the original so around 8 year old so your battery could well to be on its way out. They say a battery is only good for 5 years or so. Anyway new battery was fitted and no problem since
Post #641564 Sat Apr 27 2024 4:58pm
JonnyCJ
What news ?!
Post #641582 Sun Apr 28 2024 7:02pm
chamara
Thanks a lot for all the advice and help. Yes all good we are back in action and everythings working. But i might actually goto the LR service center to do the battery health as its been only replaced last year.
Btw why is it draining battery this quickly. I know lot of gadgets there..
Post #641587 Sun Apr 28 2024 8:14pm
