![]() | Home > General > Help please PCM P006A |
Karlp606 Member Since: 25 Jun 2022 Location: East Yorks Posts: 272 ![]() |
Sounds like you've got the dreaded manifold break, take it to a garage to get smoke tested they'll be able to diagnose. |
HMCH Member Since: 08 Dec 2023 Location: North Yorkshire Posts: 13 ![]() ![]() ![]() |
Yeah I think you could be right : (
Cpt Jack Sparrow Member Since: 07 Sep 2016 Location: Cardiff Posts: 168 ![]() ![]() ![]() |
Hi
Hi Paul
Wow just seen the video!
he bonds the metal plate over the crack on the manifold. Christian uses epoxy to do this however it's only rated to 100 degrees.
Indy just called my drivers side completely blown! So wont be able to do this repair so new manifold going in today. |
ah that's a shame, still was worth a try |
Karlp606
Hi all,
Update on mine I've finally got the time to have a look at mycar over the weekend.
If you've got oil on the sensor be more than likely a manifold leak as the oil is escaping.
