![]() | Home > Technical > online services |
SpiderPig Member Since: 13 Mar 2024 Location: Herefordshire Posts: 121 ![]() ![]() |
I don't think tethered internet access is an option (at least not mentioned in the handbook).
scrumps Member Since: 01 Aug 2011 Location: Somerset Posts: 545 ![]() ![]() |
RRSSDV8 Member Since: 26 Jan 2024 Location: Cheshire Posts: 38 ![]() ![]() ![]() |
Thanks, I am on sky mobile which uses O2, so would something like this do? Unlimited?! https://www.amazon.co.uk/O2-Preloaded-UNLI...amp;sr=8-3 |
"Valid for 1 month" is the danger signal for me. I wouldn't want to pay £35 and have it not work after a month.
Many thanks for that, much appreciated. So the fact that it says 3 network on the pack isn't a problem? its only for data and not phone signal, so doesn't matter then? |
It works fine for me. 2021 P400e Autobiography |
Just another question sorry, when I plug it in to the console in the car will the online services just start working or do I need to create an account or log in somewhere? or does it just use your in control log on details? |
It should just work. 2021 P400e Autobiography |
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1856 ![]() ![]() |
Check what you can do here: https://www.landrover.co.uk/ownership/incontrol/touch/index.html 2023 P440e SE Dynamic on order -cancelled
oh wow, thanks very much, much appreciated. I haven't seen that before, will take a look, thanks again. |
thanks Spider pig, plugged the sim in and it works now, brilliant. The only thing that is weird is that the maps on the instrument panel in between the speedo and rev counter is still the old map and not the aerial view shot? not a deal breaker, but just wondering if you can change that too? In the new Land rovers I have been in, it shows on both as aerial shots? |
No, it's just the navigation view you see in the driver display screen. I can't really see the satellite view being all that useful - it's difficult to see anything useful at a glance while you're driving.
