Home > Maintenance & Modifications > ACE removal
Reno
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Baltic Blue
ACE removal
Need some help please, 2011 3.0 diesel RRS. I'm removing the ACE and replacing it with standard bars but getting conflicting opinions about re writing the CCF files. some people say the files can be re written and that you will not get any warnings or messages relating to ACE, others say they've done but the warning still appears. Need to know if anyone has actually achieved this sucessfully before i bite the bullet, thanks.
Post #636533 Thu Oct 12 2023 12:15pm
has been discussed before
e.g
https://www.rrsport.co.uk/forum/topic58466...ce+removal
Post #641085 Wed Apr 10 2024 3:54pm
Pistnbroke
The obvious question is why?
High pressure rubber pipes available cheap.
dont change them just weld them up ... Always listen to old people or when they die you will live on in ignorance.
Post #641095 Thu Apr 11 2024 7:06am
It's a 6 month old post from someone who only posted it and hasn't posted since, so it's unlikely they're still here. (Or they are doing a cracking lurking job! Laughing )
As for "weld them up", which bits are you welding to what? And are you sure you'll get a correct amount of anti roll action from said welded up device? And if the weld fails during driving (perhaps the bits welded together can't handle the stress), what happens then?
If one must get rid of the system, at least changing the bars for real solid items means you get the correct sort of anti roll effect for the vehicle. Getting rid of the pump is the same problem for both "solutions" of course.
I do wonder why the OP ever wanted to remove the dynamic response system in the first place. The costs associated with messing around to remove the system are likely to be no saving over just replacing a leaking bar. 2012 SDV6 - it's missing a couple of cylinders
Post #641100 Thu Apr 11 2024 8:52am
Oops. I’m sure someone asked recently.
Post #641101 Thu Apr 11 2024 8:58am
Pistnbroke
These have been welded up before ......Remove pump ...shorter belt EPLS Always listen to old people or when they die you will live on in ignorance.
Post #641103 Thu Apr 11 2024 9:00am
Disco_Mikey
It's more expensive to remove the system than to replace a leaking bar as a 1 off job
Long term, it's much cheaper than (eventually) replacing both bars, front + rear pipes and a valve block Thumbs Up
Post #641137 Fri Apr 12 2024 8:01am
I'm on my second RRS, both of which had dynamic response anti-roll bars fitted. One was sold at 175k miles and the other is currently at 155k miles. I have replaced a grand total of one rear anti-roll bar and that was on the first RRS and it was done under LR warranty.
Are these items really that unreliable that people are too scared to just repair them properly and enjoy the vehicle as it should be? 2012 SDV6 - it's missing a couple of cylinders
Post #641143 Fri Apr 12 2024 11:52am
My front dampers are getting ready for replacement. They're the active ones. I think I'll save money by fitting some scaffold tubes instead. Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter 2012 SDV6 - it's missing a couple of cylinders
Post #641144 Fri Apr 12 2024 11:53am
Disco_Mikey
Maybe you were just lucky Laughing
Given the supply issues around pipework lately, we've had a massive increase in queries above removing the system. Not financially, just to get the cars back on the road again. JLR should hang their heads in shame. 7 months wait on a few bits of steel pipe is not acceptable Censored
Post #641147 Fri Apr 12 2024 2:42pm
LR giving a Censored about older vehicles is a standard bug bear these days. They don't. And eventually the people that spend £100k on a LR will figure this out (via reducing second hand values) and LR will learn via their bottom line.
The thing is that the pipes can be replaced with other hydraulic-rated pipes. And it'll be cheaper than buying LR's Unobtaium pipes. 2012 SDV6 - it's missing a couple of cylinders
Post #641160 Fri Apr 12 2024 11:53pm
rayodunne
Canada 2009 Range Rover Sport Supercharged Santorini Black
You could buy these or similar from hydraulic shop and build the sections yourself.
These fittings and tubing are good for 3000psi or more.
And buy one of these to do bends:
https://www.amazon.com/ARES-10032-Degree-T...09HFZG8PP/ 2009 Range Rover Sport Supercharged
Post #641225 Wed Apr 17 2024 4:30pm
