Home > General > Best engine choice for a used RRS?
4535jacks
I am in the market for a used RRS and looking at MY18 to MY21 depending on spec. I would use it off road so a Dynamic HSE seems like the right choice as it has a low range transfer box.
However, I am really struggling to choose which engine. Originally I was thinking SDV6 as I prefer diesels but reading on here people's accounts of crank failures and the resulting repair bill, I am not sure now. I have also been looking at the D300 MHEV and P400 PHEV but I am concerned that buying a second hand hybrid will mean that within my ownership (5-7 years), I will have to replace the battery for £ks due to lose of charge or failure..
Is there an engine choice that will offer the least chance of engine failure or a significant bill over 5-7 years of ownership?
Looking at buying approved used and driving 10k per year.
TIA,
Jacks
Post #641068 Wed Apr 10 2024 7:40am
SpiderPig
Later cars typically have updated components, so whatever problems you see with the older cars should have been ironed out to some extent.
Approved used will give you a years warranty so you can get any issues sorted out fairly easily (and you're not tied into LR servicing in that time). PHEV batteries have a 6 year (60K) warranty.
Personally, I'd lead you toward a MY21.5 as it'll be the most up-to date. Choice of engine depends on what you need from it. Most of my journeys are less than 30 miles, so the PHEV works very well for me.
D300 will of course be cheaper (you'll always pay a premium for PHEV).
All Sports will have a low range option. 2021 P400e Autobiography
Post #641070 Wed Apr 10 2024 7:59am
The most reliable engine in the L494 is the V8 Supercharged, followed by the SDV8.
It all depends if you will do lots of driving or not: SDV8 in case of the former, and SCV8 for the latter Thumbs Up --
Post #641071 Wed Apr 10 2024 8:01am
SpiderPig
I don't think the V8s were offered for post 2018? 2021 P400e Autobiography
Post #641072 Wed Apr 10 2024 8:12am
The SDV6 has been known to have crank failures but there are a lot of SDV6 engines out there - they're in the RRS, Discovery, FFRR and the rate of failure isn't monstrous (albeit awful for those that suffer it).
Likelihood of a crank failure is probably the same as likelihood of having to replace a MHEV/PHEV battery, frankly.
The best way to maximise longevity with these cars is to find and use a decent LR specialist, not a LR dealership. Someone who will service it properly and do so with care - that goes a long way to reducing the risk of failures.
I'd suggest looking at bit older and getting the last of the SDV8. That'll come with low range and the active rear diff which makes it even better off road. 2012 SDV6 - it's missing a couple of cylinders
Post #641073 Wed Apr 10 2024 8:46am
Yes, but I'd bet most L494 that had it as an option never had that option chosen, so finding one in the second hand market will be trickier. And that will be increasingly so as the years go on as currently (L461) low range is only standard on the petrol versions - the diesel options require it to be fitted as an option even in AB spec.
The L461 petrol versions appear to have lower towing limits (3t rather than 3.5t) and slightly less ground clearance, strangely. 2012 SDV6 - it's missing a couple of cylinders
Post #641074 Wed Apr 10 2024 8:56am
4535jacks
Yes you are probably right but from research it seems the MHEV uses a 48v battery which I hope wouldn't be too expensive. Second hand 48v batteries are going for £700 on ebay.
In my mind keeping a hybrid for so long, a battery replacement is inevitable. I think this makes the PHEV economically unviable for very long term ownership. That said, as EV become more common maybe better options for repair become available.
Post #641075 Wed Apr 10 2024 8:56am
4535jacks
Would a D300 non-MHEV be a better choice than the SDv6 on the P494?
Post #641076 Wed Apr 10 2024 9:46am
SpiderPig
The PHEV battery should last you for at least 100K, so for your mileage, that's 10 years.
On the other hand, it's possible in the future that fossil fuel prices may be taxed more as the demands for EV vehicles rises, so it's difficult to gauge whether it's more economical in the long term to pay for petrol/diesel or to offset that and buy a larger amount for a new battery in 15 years time.
It's all in gut feel and guesswork really.
You'll also need to factor in insurance and VED costs over time for the different variants.
At the end of the day, however, no one buys a Land Rover as an economical choice - there's a lot more cheaper/more efficient cars out there. Expense is hand-in-hand with the brand and that's what we (as LR owners) fully accept. 2021 P400e Autobiography
Post #641077 Wed Apr 10 2024 10:55am
I reckon the plain D300 would be a great choice if you can find one. The engine was well received at the time, as I recall, and it means you don't have the crank or battery issues to worry about.
The key will be finding one with low range too. 2012 SDV6 - it's missing a couple of cylinders
Post #641078 Wed Apr 10 2024 12:56pm
?si=8lP4Pjjhc1OKs5U8
Post #641081 Wed Apr 10 2024 1:33pm
SpiderPig
Yeah, a lot of straight talking from Harry's Garage there.
He doesn't really address any future for ICE cars though, just explores the EV/battery side of things.
Right enough that the D300 is cheaper than the P400e.
He's taking the side of economics here, but of course he could easily afford to run a P400e if he wanted to. 2021 P400e Autobiography
Post #641082 Wed Apr 10 2024 2:26pm
