Home > Technical > Park break release
karlos01
Park break release
hi folks had my 2006 4.2 V8 supercharger parked up for a year put a battery on it fired up fine
had it ticking over for 20 minutes went through all the car settings and all is good
went to move it and the back passenger wheel is locked on tried to move forwards and backwards was parked in P position I've put hand break on and off to see if that was problem I was thinking maybe it has come on a stuck on
so question is where is the emergency release cable located and if I pull it can it be reset?
Post #640979 Fri Apr 05 2024 6:25pm
First.
Leave the park brake off over night. (If it’s chocked)
Take the wheel off. Bang the drum with a hammer and see if you can get the brake released.
Put wheel back on to get more leverage with your hands.
Post #640981 Fri Apr 05 2024 7:21pm
karlos01
it's chocked now with hand break off
was thinking about taking wheel off and hit it with my rubber mallet I've got to see if that would free it up
Post #640982 Fri Apr 05 2024 7:23pm
karlos01
left the park break off for two days had the wheel off breaks are free think the park break is seized on
is there away to releasing it or is it a calliper and disc off job?
Post #641016 Sun Apr 07 2024 1:55pm
I’d take the disc off.
There is a pull cord near the gear selector. It needs pulling hard. I’d only do this as a last resort though. As it could be expensive to recover from.
Post #641017 Sun Apr 07 2024 2:36pm
karlos01
thanks Andy that what I was thinking take disc off
Post #641019 Sun Apr 07 2024 2:48pm
I doubt pulling the emergency release will help if it's the actual mechanism in the wheel unit itself that is seized. 2012 SDV6 - it's missing a couple of cylinders
Post #641026 Sun Apr 07 2024 7:40pm
NoExpert
Agree with @RRSTDV8, the levers on the shoes are likely seized. Banging on the outside of the drum area is about your only hope till you get it to free up enough to get the rotor to turn. Once the rotor can turn you can get the adjustment window aligned to back off the star wheel adjuster. Had to do this not too long ago on a Disco 4, it’s not fun, but not impossible. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #641029 Mon Apr 08 2024 1:23am
karlos01
is the adjustment window the little hole in the hub ?
I've got a grub screw that holds the disc in place and noticed a spare hole
Post #641031 Mon Apr 08 2024 5:25am
Yes, but not going to be of much use if you can't turn the disc to line it up with the adjuster yet, as suggested just give the disc a few good whacks with something like a copper mallet or dead blow hammer.
Post #641034 Mon Apr 08 2024 7:29am
karlos01
I did try to smack it with my heavy rubber mallet will have another go at weekend
I'm hoping the handbrake hasn't gone on one side ?
Post #641037 Mon Apr 08 2024 2:07pm
karlos01
all done loosened the disc and moved with bar then placed wheel on and turned a few times replaced everything and took for test run and all was OK
now have this come up when I turn hard left lock
the wheels are straight but the computer is saying the off centre can it be reset with diagnostic tool
Post #641164 Sat Apr 13 2024 10:23am
NoExpert
Need to have the Steering Angle Sensor recalibrated. This takes some sort of diagnostics capable of doing this. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #641170 Sat Apr 13 2024 7:06pm
karlos01
managed to sort it out with a hawkeye like you said it needed re calibration doing on it
Post #641174 Sun Apr 14 2024 6:42am
Pistnbroke
Only use the handbrake if on a ferry or channel tunnel. Always listen to old people or when they die you will live on in ignorance.
Post #641179 Mon Apr 15 2024 5:28am
