Home > General > RRS 4.2 S/C front driver side is leaning lower |
wiztaz Member Since: 28 Dec 2021 Location: Essex Posts: 41 |
Hope everyone is having a lovely Easter break!
Mon Apr 01 2024 7:57am |
JonnyCJ Member Since: 25 Apr 2011 Location: Wirral Posts: 371 |
Hmm - one corner would have meant a leak on that corner airbag or valve connection. All 4 dropping sound like the tank isn’t holding pressure or a compressor fault.
Mon Apr 01 2024 9:25am |
Yes i definitely removed brown 5 top row second from right
Mon Apr 01 2024 11:25am |
Any updates? |
Wed Apr 03 2024 6:30pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4966 |
It should be a yellow 20a fuse you are removing overnight. |
Fri Apr 05 2024 10:15am |
Would you mind circling the one I need to remove? |
Fri Apr 05 2024 11:34am |
Fuse 26
Fri Apr 05 2024 12:20pm |
Thank you so much Andy:) I will try that over the weekend and report back. |
Fri Apr 05 2024 1:08pm |
Tried this over night and the car pretty much held its height. Front dropped by only 1cm in the arches but back stayed exactly the same. Front D - 19cm / 17.5cm Front P - 17cm / 16cm Back D - 18.5cm / 18.5cm Back P - 19.5cm / 19.5cm As soon as i put the fuse back in it dropped to normal height as below Front D - 14cm Front P - 14cm Back D - 15cm Back P - 17cm last few days i've noticed that even if I leave the car parked for 1hr its dropping and when I start it again the car starts leveling itself. Front drivers side suspension strut has already been changed. I will get front passenger side changed this weekend so they are in pairs. Any ideas? |
Thu Apr 11 2024 6:19am |
If you haven’t already, clean the front valve block and change the seals.
Thu Apr 11 2024 7:21am |
