Home > Maintenance & Modifications > Trafic indecators.....
andrew kennedy
France 2006 Range Rover Sport TDV6 HSE Maya Gold
2006 Sport. My traffic indicator control is showing a fault. When indicating to go right, the speed of the flash is twice as fast as usual (indicating left remains as it always has been...a slow ticking thyme). I presume I need to change the control mechanism? Is this is a simple procedure? If so, where can I find the part on the car that needs changing? When ordering the part, does the part have a particular description. Andrew Kennedy
Post #640683 Mon Mar 25 2024 7:11pm
Have you checked that you have not got a blown bulb?
Post #640684 Mon Mar 25 2024 7:22pm
You have a bulb failed
Post #640685 Mon Mar 25 2024 7:31pm
Pistnbroke
This is intended to show a blown bulb but on the odd occasion over the last 40 years as an auto electrician I have found one bulb not to be drawing sufficient current so although it flashes it triggers the fail mode ..just change the bulbs on one side. Always listen to old people or when they die you will live on in ignorance.
Post #640692 Tue Mar 26 2024 7:00am
andrew kennedy
Hi Andy and Col. Traffic indicator lights are working okay, however, I have recently changed the rear off site lighting unit - so what am I looking for to find the fault? Andrew Kennedy
Post #640698 Tue Mar 26 2024 9:30am
On the unit you replaced.
Clean the contacts. And replace the bulb. That gives it a good chance to fix the issue
Post #640700 Tue Mar 26 2024 9:37am
andrew kennedy
Okay now I know....learning all the time....bulb on the front offside blown. Thanks for advice!!!! Andrew Kennedy
Post #640738 Wed Mar 27 2024 7:22am
A nice simple, cheap fix is always a pleasure. Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #640739 Wed Mar 27 2024 7:31am
