![]() | Home > Technical > 2014 TDV8 Timing Chain - One Bank Gone!!!! |
They do fail now and again on the v6. I think they are similar engine designs |
2 RRS Member Since: 04 Sep 2016 Location: Shropshire Posts: 158 ![]() ![]() ![]() |
I have seen a couple of posts over the years on the fullfatrr forum (where I am a member as have both a L494 (SDV6) & L405 with the V8 ). I recently rebuilt my 4.4 after a spun big end bearing. I think you will possibly find the cams will require replacing as I have seen spun lobes as they are an interference fit.
Garrfield Member Since: 20 Dec 2023 Location: Wokingham Posts: 34 ![]() ![]() ![]() |
Wow!! Unfortunate for you but a well described operation and the pics are a great help. When you see the front end removed it is quite a shock at how much pipework is involved in these cars!!
Yep, 2 thousand miles in and running perfectly - thank god!
Thanks Mike, sometimes to much information is sooooo scary!!! It seems regardless of which way I go there is one hell of a lot of work just to get to the chains before even considering changing them.
