Home > General > EGR blank on 3.0 tdv6 2010 RRS *PROBLEM FIXED*
JAMO1282
England 2011 Range Rover Sport 3.0 TDV6 HSE Lux Santorini Black
Hi guys
After some advice on doing a egr blank/delete on the above RRS. Has anyone done this and where do you buy the egr blanks kit from as all the ones I see advertised are for 2.7 TDv6? Will the vehicle need remapped also?
Reason for thinking about blanking the Egr is, I just replaced a faulty glow plug and noticed the egr was absolutely caked up in gunk, I've never seen 1 so bad. Gave it abit clean the put it back on. However now the RR is going into limp mode but its not putting a fault code up, it's never done this until I have had the egr off so I'm presuming it has to be this?
Thanks
FIXED A PIPE HAD CAME OFF THE EGR VALVE 🤦‍♂️🤦‍♂️🤣🤣
Post #640454 Sat Mar 16 2024 6:38pm
Pistnbroke
Thats because some 2.7s dont throw a warning light that needs re programming to turn off. All the 3s do Always listen to old people or when they die you will live on in ignorance.
Post #640459 Sat Mar 16 2024 10:24pm
