sathees@blueyonder.co.uk
![](templates/vbnew/images/spacer.gif)
Water Leak and Fault codes | |
does anyone who live near KT4 postcode has IID tool they can help with?
I bought a RRS 19 plate about 5 months ago, JLR Dealer, about 2 weeks ago , my car would not start, so got the road side assistance called in , The front passenger footwell carpet was soaking wet, removed the floor carpet, underneath the carpet form was drenched with water and there was water puddle as well.
There ware lot of wires running across that part,
The official JLR Dealer, who I bought the car from said the issue was door seals, to my dismay JLR warranty doesn't cover water ingress!!
But as I only just bought the car only 5 months ago, i have legal rights under consumer protection act 2015, so I pointed this out and suddenly JLR covered 80% and dealer covered 20% to fix the door seal and replaced from front carpets.
What they did not do investigate are the fault codes the car was throwing out, even though they had these printed out when the car went in for repairs. How I got to know is , once I got the car back, I took it independent garage and got them to print out the current fault codes, to my surprise, all the fault codes they had printed out was still showing up !!!!!,
I pasted the current fault codes read i got back.
Any advice on these how serious are these?
ABS (Anti-Lock Brake System Control Module) 6 problems exist
1.U0100-87 Lost Communication With Engine Control Module/powertrain Control Module 'A' - Missing Message
2.U0115-87 Lost Communication With ECM/PCM "B" - Missing Message
3.U101C-87 Lost Communication With PCM Node D - Missing Message
4.U101E-87 Lost Communication With PCM Node J - Missing Message
5.U1020-87 Lost Communication With PCM Node P - Missing Message
6.U0080-87 Vehicle Communication Bus F - Missing Message Confirmed
BCM (Body Control Module) 1 problem exist
1.U201B-54 Control Module Calibration Data #2 - Missing Calibration Confirmed
CHCM (Chassis Control Module) 1 problem exist
1.U0046-81 Vehicle Communication Bus C - Invalid Serial Data Received.
GWM (Gateway Module 'A') 1 problem exist
1.P0A1A-87 Generator Control Module - Missing Message Confirmed
IPMA (Image Processing Module 'A') 1 problem exist
1.U0001-81 High Speed CAN Communication Bus - Invalid Serial Data Received. Confirmed
IMC (Infotainment Master Controller) 1 problem exist
1.B1DE3-31 Multimedia Link - Driver Assistance Domain Controller [B1DE3] - No Signal Confirmed
IPC (Instrument Panel Cluster Control Module) 3 problems exist
1.B108E-04 Display - System Internal Failures Confirmed
2.U0055-87 Vehicle Communication Bus D - Missing Message
3.U3000-87 Control Module - Missing Message
PAM (Parking Assist Control Module) 1 problem exist
1.U2300-55 Central Configuration - Not Configured Confirmed
ECM (Engine Control Module) 3 problems exist
1.U0402-68 Invalid Data Received From TCM [U0402] - Event
Information
2.P2B61-73 Engine Coolant Flow Control Valve Stuck Closed
[P2B61] - Actuator Stuck Closed Pending
3.P26CB-72 Variable Coolant Pump Performance/stuck Off - Actuator Stuck Open Pending
TCU (Telematic Control Unit Module) 2 problems exist
1.B14A9-13 BroadR-Reach� Link - Telematics (+) - Open Circuit Confirmed
2.B14AA-13 BroadR-Reach� Link - Telematics (-) - Open Circuit Confirmed
RCM (Restraints Control Module) 2 problems exist
1.B0020-13 Left Side Air Bag Deployment Control - Open Circuit Confirmed
2.B0052-13 Passenger's Safety Belt Sensor - Open Circuit Confirmed
ICDM (Interactive Control Display Module) 2 problems exist
1.B14A2-02 APIX2 Display Link - Touch Screen - General Signal Failure
2.B14A2-13 APIX2 Display Link - Touch Screen - Open Circuit
IDMA (Interactive Display Module A) 2 problems exist
Sun Mar 10 2024 2:48pm |
