Home > Faults & Fixes > Pressure increases too rapidwhen filling reservoir C1A18-64
Iomegas
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Hi folks started car up today got triangle yellow with the above fault code.The car was not low on any corner moved suspension up and down front seemed slower than back.Deffo slower at moving up and down then normal .Plugged in diag tool and noticed after moving up and down a few times compressor temp had risen to around 75 deg c.Gallery pressure on live data moved up at a steady speed and then down when moving suspension down.The code wouldn’t clear at first took for a run cane back left car off for 15 mins then when started back up no code showing light cleared switched back of and on no code or light.Im thinking possible valve block issue or to service compressor and put new filtration granules in.Any ideas would as always be appreciated.The car is a 2013 RRS with 69000 AMK compressor.
Post #640096 Fri Mar 01 2024 4:19pm
Lrstaylor
United Kingdom 2006 Range Rover Sport Supercharged Bali Blue
Get the compressor out and give it a service
Post #640102 Fri Mar 01 2024 6:45pm
Iomegas
Hi appreciate your reply ordered a service kit fingers crossed Thumbs Up
Post #640103 Fri Mar 01 2024 6:47pm
Iomegas
Hi following my earlier post Pressure increases too rapidwhen filling reservoir C1A18-64 and jut in case anyone else has the same problem I found the fault and fixed it.
The fault was to do with the reservoir middle valve block I replaced and cleared code and the car rises as it did before fault and no code,
Now I know it may have been the actual pressure switch on the block but got a block new for £65.00 and bought a new switch and seal kit to refurb the original, message hope this is useful to others. Thumbs Up
Post #640815 Sat Mar 30 2024 10:21am
Lrstaylor
Well done Thumbs Up
Post #640816 Sat Mar 30 2024 11:10am
