Home > General > Ace pipes LR015144 |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 949 |
I think everyone is waiting on them,, every comment I have seen lately points to them being on back order so unless you can find a hydraulic shop that can make you a set. 2010 RRS, TDV8
Sat Oct 28 2023 5:57pm |
Spiller2001 Member Since: 28 Oct 2023 Location: Gloucestershire Posts: 3 |
Thanks |
Sun Oct 29 2023 6:22pm |
AllanMac Member Since: 15 Jan 2024 Location: Aberdeen Posts: 3 |
Hi All. New to this forum so hopefully I am asking in the correct place. I am currently running a 2013 RRS SDV6 with an Overfinch bodykit and also experiencing a leak on one of my ACE pipes coming from the pump rendering my the vehicle unusable, but cannot find any supplies of the LR01544 ACE pipes front kit and nobody seems to know when they may be back in stock. Anybody know of any supplier that may have current stock, or have some inside information as to when they might be back in stock?
Mon Jan 15 2024 12:18pm |
JAMO1282 Member Since: 18 Jan 2024 Location: Cumbria Posts: 21 |
I'm in a similar predicament mate, no stock of the pipes for a 2011 RRS TDV6 😔😔. I was wondering if a hydraulic company would be able to make them if I take the old ones in 🤔 like Pirtek.... |
Fri Jan 19 2024 8:25am |
Hi Jamo1282, I have actually managed to do a temporary repair by cutting out the bad section and getting Pirtek to make up a piece of hydraulic hose with 10mm compression fittings rated to 180 bar, (next size up from the 135 bar system working pressure which I have read may spike to 150 bar on hard use so erred on the safe side), as it was the pressure line from the pump that started leaking on mine just behind the drivers side front suspension. So far so good after about 60 miles driven with no alarms and no more fluid leaks. I was able to cut back one side to a clean bit of pipe which was under the clamp, but the other side was still pretty corroded but still managed to seal after a bit of cleaning up the worst of the corrosion. The 180 bar WP enabled torquing up the compression fittings with a high torque. Have still ordered a complete set to replace my front pipes but at least I have an option to repair whilst awaiting the back order to arrive which may be some months yet!
Fri Jan 19 2024 11:14am |
Hello mate thankyou for your reply. 1 of mine that is split is the bottom pipe right where it bend round under the chassis and attached to a rubber pipe, I've only had a quick look at the moment so will get a clearer idea when I get it up a hight.. Its good to know that Pirtek can manufacture something tho..
Fri Jan 19 2024 11:25am |
Hopefully the photos should be attached now. First time using this forum. I have ordered my pipes through Peter Vardy Land Rover in Aberdeen, Scotland and don't have to pay for them until they come back in stock. They will call me when they are back in stock. They have a few sets on back order for various customers but still don't have an ETA on when they might receive new stock.
Fri Jan 19 2024 12:13pm |
Yeh my local land rover dealer in carlisle wants me to pay upfront for the pipes 😔. Think I'm going to try your fix, will get the bit cut out and visit Pirtek.
Fri Jan 19 2024 4:09pm |
Flinders Member Since: 12 Dec 2014 Location: West Yorkshire Posts: 126 |
Jamo1282 have you managed to source parts or get from Pirtek? If from Pirtek how much did it cost and was it easy to fit?
Wed Feb 28 2024 9:20pm |
Thu Feb 29 2024 9:30am |
Thank you for the positive update! We have some hope now!
Thu Feb 29 2024 8:55pm |
Your welcome. I'm on a waiting list also but if this continues to do the job probably won't bother getting them..
Thu Feb 29 2024 9:13pm |
Notyalc Member Since: 01 Aug 2022 Location: Northumberland Posts: 40 |
No 3 was definitely true, they lost or could not find loads of parts. Amateurs! |
Fri Mar 01 2024 4:24pm |
Jamo1282 you’re lucky you can do the work yourself I’ll have to take ours to a garage to get it done . To replace the arc pipe with the pirtek pipe did you manage that without taking the body off?
Fri Mar 01 2024 7:47pm |
