![]() | Home > General > Service Required Message |
TTR Member Since: 14 May 2023 Location: West Yorkshire Posts: 166 ![]() ![]() ![]() |
Ehup all,
It most likely read unavailable when it showed min. You need to wait approximately ten minutes after the engine is shut off to get an oil level reading. Or bring up the screen with the hood and drivers door open and double tap the cruise control cancel button to get live data.
Eh up No Expert
If you are unsure, and as your time is your own, why not use the correct procedure outlined in the workshop manual, a bit long winded but works with no problem.
Not sure about others, but mine says add 1 liter at four ticks down. It will say oil level is okay until it’s four ticks/1 liter low. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
May vary depending on which revision Owner Handbook you have I guess, that extract is the same as in the handbook that came with my MY13 car, no sure what message may appear other than level O.K as have never had to add oil between services.
