![]() | Home > Technical > Chassis dampers worn out ?? |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9025 ![]() ![]() ![]() |
Or, perhaps, just fit the correct item (for c.£60). |
Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 425 ![]() ![]() ![]() |
You just dont get it ...dont spend money on old cars !!
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5044 ![]() ![]() ![]() |
They did away with the front ones on later cars for some reason, if you still have front ones fitted try fitting to the rear as the same part.
You bought a vehicle that is known to require more than a wipe over with an oily rag. And now you're going to bodge everything on it making it worthless in future. Seems like you've wasted your money already. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Good idea col but I already ordered the turn buckles.
