Home > General > RRS 2005 supercharged ..transmission error when drive engage
Page 2 of 3 <123>
Disco_Mikey
I've had this exact fault. Switching lights on cured it, and I can't remember the logic behind it
Root cause was a corroded splice joint in the front of the NS sill. Same side as the central locking splice, just further forward Thumbs Up
Post #639752 Sun Feb 18 2024 8:12am
Disco_Mikey
https://www.disco3.co.uk/forum/topic79211-15.html
Post #639753 Sun Feb 18 2024 8:14am
Markieboy123
United Kingdom 2005 Range Rover Sport Supercharged Stornoway Grey
Many Thanks Mikey…
Looks like the live feeds to the shifter are a green pink wire going to BCM fuse 33 a 5amp and purple blue wire going to BCM fuse 44 another 5amp.
If it ever stops raining I will be out with my meter doing some more investigating
Post #639754 Sun Feb 18 2024 9:01am
Disco_Mikey
Completely wrong Embarassed Laughing
Post #639755 Sun Feb 18 2024 9:30am
Markieboy123
The weather or my assumption?😂
Post #639758 Sun Feb 18 2024 10:43am
Very interesting your PRND aren’t illuminated.
P should be red most of the time the ignition is in I
They are all backlit green. And when in position RND go orange
From memory.
Mikey I think he’s already had a go at one red splice
Post #639764 Sun Feb 18 2024 11:40am
Yeah it is worth checking those fuses you mention if you aren't getting orange/red lights.
Otherwise check the black ground wire has a good ground
Post #639766 Sun Feb 18 2024 12:05pm
Markieboy123
When I looked at the fuses in the BCM their was a fair bit of corrosion so removed the BCM fusebox
Post #639767 Sun Feb 18 2024 1:21pm
Markieboy123
Ever wondered what it looks like inside the BCM
Post #639768 Sun Feb 18 2024 2:20pm
You’re keen to remove that. Laughing Poor connection you reckon ?
It contains the imboliser code so don’t break it!
Post #639774 Sun Feb 18 2024 3:48pm
Disco_Mikey
Sorry, my ramblings post
Easy to check for power at the gear selector, and the fuse, see which end the problem lies at Thumbs Up
Post #639775 Sun Feb 18 2024 4:08pm
Markieboy123
Called it day when it started to get dark.
Cleaned all the fuse and relay contacts with contact cleaner and checked all the fuses before reassembly.
Managed to get the BCM out without removing the lower glove box but would not go back in, good old other owners and YouTube with a video how to remove the hinge pins.
Will crack on in the week to refit the BCM then fingers crossed I have not f**ked it up.
Thanks Guys for all the pointers and advice
Much Appreciated 👍
Had a look at the selector too 😂
Post #639780 Sun Feb 18 2024 6:13pm
Markieboy123
Also £2.11p better off from the change found under the gear shifter assembly
Post #639781 Sun Feb 18 2024 6:14pm
When you have refitted the rear connectors, if you can still see red on the connector it’s not fully inserted
P.s is it supercharged ? Profile says tdv6
Post #639782 Sun Feb 18 2024 6:23pm
Markieboy123
Yeh my old sport was the TDV6 , Mr Khan made me sell that due to the ULEZ expansion.
However I am Ok to drive a 4.2 V8 supercharged petrol car.
Will amend my profile
Post #639783 Sun Feb 18 2024 6:43pm
Page 2 of 3 <123>
