![]() | Home > Technical > Red Suspension light ride height sensor lost contact |
I would check the belt. (And maybe the tensioner at the bottom at fault)
erickwan Member Since: 27 Mar 2016 Location: P Jaya Posts: 138 ![]() ![]() |
If he bridge the pump relay and the pump works, perhaps you might want to change the relay or at least test that it's working as it should. |
