Home > Technical > Possible turbo issue? |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8971 |
It could very well be a split inlet manifold. It's a known issue with the SDV6 and will give a loss of performance (and a red light on the dash).
Sun Dec 17 2023 8:27pm |
Igaffz Member Since: 17 Dec 2023 Location: Newcastle Upon Tyne Posts: 10 |
Thanks for the prompt reply mate, it defo isn’t a split manifold and there isn’t any lights on the dash!
Sun Dec 17 2023 8:45pm |
Have you checked for a split manifold?
Sun Dec 17 2023 11:19pm |
Iomegas Member Since: 15 Nov 2020 Location: Newcastle Upon Tyne Posts: 213 |
Hi hope you get sorted ,I have a smoke tester if you wanted to test for any leaks for peace of mind I’m In Newcastle also but happy to help have Code readers also if anything needs cleared. |
Mon Dec 18 2023 7:33am |
Thanks for the help I’ll keep you informed with the outcome 👍🏻 |
Mon Dec 18 2023 5:17pm |
Mon Dec 18 2023 6:50pm |
Well I thought I’d update my turbo issue. Apparently the right turbo was knackered. I was advised to do both so it had two new turbos, gaskets and pipes. Also had one new mass sensor and a new throttle body and a as fuel filter.
Thu Feb 15 2024 7:27pm |
