Home > General (L494) > Infotainment Audio, SatNav & Bluetooth Failed |
Grimble Member Since: 21 Aug 2020 Location: Staffordshire Posts: 260 |
Ordered!
Tue Feb 13 2024 11:07am |
Also I have seen videos showing drilling out of the stub from the top and the bottom, which is easier?
Tue Feb 13 2024 11:10am |
Oooff, bad luck. I have had no issues other than drips of water collecting in the rubber boot tray, it seems like it runs down the headlining and out of a join in the C pillar trim. But best not to push my luck.
Tue Feb 13 2024 11:59am |
Karlp606 Member Since: 25 Jun 2022 Location: East Yorks Posts: 245 |
Just on the drain part to fix to the rubber drain hose you can use the flared copper pipe or metal one as the OP mentioned above, but theres also these from the previous range rover. Just cut the top off so its flush with the sunroof drain and then seal around it with some tiger seal and push into the original drain hose ;
Tue Feb 13 2024 12:09pm |
Garrfield Member Since: 20 Dec 2023 Location: Wokingham Posts: 34 |
Good luck. The main thing is to make sure it doesn't run down the B pillar the water runs everywhere from there. Current: 2014 4.4 TDV8 Autobiography 110k miles......will it make the 200k like the Boss did1 Previous: 2007 3.6 TDV8 200k miles (The best, gone but not forgotten) |
Tue Feb 13 2024 12:34pm |
Hi Karl, I found a copper pipe that had flares either end so only had to be cut to length. I am a bit dubious about it actually staying in place for long. These older rubber connectors look the part tho. Current: 2014 4.4 TDV8 Autobiography 110k miles......will it make the 200k like the Boss did1 Previous: 2007 3.6 TDV8 200k miles (The best, gone but not forgotten) |
Tue Feb 13 2024 12:38pm |
All the bits on order including an extra-long series 10mm drill bit.
Tue Feb 13 2024 4:33pm |
How did you get on Grimble? Mine has worked a treat and all sealed and water tight. Current: 2014 4.4 TDV8 Autobiography 110k miles......will it make the 200k like the Boss did1
Sun Mar 17 2024 9:01pm |
Did one side and all been ok so far.
Wed Mar 20 2024 11:38am |
