Home > General (L494) > Oil Change Warning / Advice
Nick900
Hi Everyone,
3.0 SDVT currentlly on 88 K just performed 10K service early. Full Land Rover SH until last 3 services I have completed. Both previous done using vacuum extraction method.
Noticed the 90* connector is starting to leak. Not sure if it is a crank case breather or turbo return hose. Advice on what would be welcomed. I didn't follow up to check where it was routed.
Removed the connector and cleaned it. Will naturally replace but would imagine if it failed would cause catastrophic damage. Would suggest you all check this connector during the next service.
Might anyone have the part number or know the exact size of if the connector can be purchased separately?
Thanks
Nick
Post #639583 Sun Feb 11 2024 5:27pm
Nick900
https://www.rrsport.co.uk/gallery/albums/u...rge~0.jpeg
Post #639584 Sun Feb 11 2024 5:27pm
 2012 SDV6 - it's missing a couple of cylinders
Post #639592 Sun Feb 11 2024 7:52pm
Nick900
Following research the actual part number is LR054148 or LR035439
It is the end of the hose connecting to the sump that the other end is where you preform the oil extraction from. It would appear you cannot buy the connector alone, with the cost of the whole pipe being about £130! Just need to figure out the size and details of the fitting which is the only leak.
Thanks
Nick
Post #639594 Sun Feb 11 2024 11:55pm
