![]() | Home > Technical > Reason for Crankshaft breakages and how to avoid. |
erickwan Member Since: 27 Mar 2016 Location: P Jaya Posts: 138 ![]() ![]() |
Lots of other engines suffer a lot more abuse with a lot less damage. |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9051 ![]() ![]() ![]() |
And the vast majority of LR V6 diesels do big miles with only normal servicing and using 5W-30 oil at 16k mile intervals (or whatever the book requires for that model). 2012 SDV6 - it's missing a couple of cylinders
Perhaps someone who had to crank the thing for several seconds each time should have had that looked at. A fuel pump is cheaper than an engine. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Karlp606 Member Since: 25 Jun 2022 Location: East Yorks Posts: 273 ![]() |
Ive said it before on a few other forums ;
Why take it off-road? |
The engine makes peak torque at low revs. At high revs, the torque is c.100lbft less than at 1500-2000. Lugging at low revs puts more strain on a torque sensitive component. Yes, driving around on the rev limiter won't do it any favours, but making occasional use of the full rev range available isn't the cause of these [relatively rare] failures. And the vast majority of the engines aren't made of "weak materials" which is why the vast majority don't snap their cranks. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
I’m having a hard time with that one. Ravenol makes FLJ 5w30 C1, Castrol makes Edge Professional 5w30 C1, LiquiMoly makes 5w30 C1, Quantum 5w30 C1, Shell Helix Ultra 5w30 C1 and many others. The ACEA C1 class has been discontinued as an oil specification for new engines. It has not been discontinued by oil manufactures that I’m aware of. I absolutely agree with giving the engine some running time before driving off as well as after a long run or a spirited drive. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory Born and raised in So Cal. Moved to the UK in 2018 for a few years. Now in Poland and looking at moving back to the UK. |
[quote="RRSTDV8"]
If ever there was poor assembly work, "weak" materials or simply poor design, then the engine was sold on a "not fit for purpose" condition. In the USA, a class action lawsuit would ensue. Some lawyer would want to take that to the Courts on a no-win, no-fee basis. |
Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 440 ![]() ![]() ![]() |
Quoting from LR time " Oil " video and cannot find an oil here that is over the specified >3.5 sheer required.
Citroen C6:
And in the RRS, that same engine also had a 190kW (254hp) version. And the L494 3.0V6 diesel increased that to c.300hp/516lbft. 2012 SDV6 - it's missing a couple of cylinders
Exactly, which is why I noted the years for the specs listed. Also worth noting is the later mentioned by RRSTDV8 also run the 8HP 8 speed auto transmission. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5037 ![]() ![]() ![]() |
As noted the earilier RRS 2.7 is closer in age and design to the C6, and Jaguar and the Pug.
