Home > Maintenance & Modifications > Leaking ACE pipe question please?
Gas-guzzler
United Kingdom 2007 Range Rover Sport TDV8 Sumatra Black
Hi guys,
Managed to track down which pipe is actually leaking (they’re all quite badly corroded) and it’s the reservoir return line where it kinks just over the tie rod. Question is, (as a temporary fix til funds are available to do it properly with all new lines) with it being a reservoir return line I’m thinking the pressure will be quite low, can I cut the line off just prior to the leak and fit some hydraulic hosing and secure with jubilee clips or is this destined for immediate failure? Just wondering if anyone has tried this and if it worked? Thanks guys.
I’ve tried catch it in this photo and circled the leaking area in red.
Post #639351 Sun Feb 04 2024 2:24am
Pistnbroke
Have a look at this post .might help in long term . These hose places are in all the main towns....I am certain you could bypass it if its a return line
https://mail.yahoo.com/d/folders/1/message...mp;.src=fp Always listen to old people or when they die you will live on in ignorance.
Post #639354 Sun Feb 04 2024 9:24am
Gas-guzzler
That sounds great, thanks for the reply.
Can’t open your link though. Probably a snag my end. Not great with tech stuff. Question
Post #639381 Sun Feb 04 2024 11:43pm
Pistnbroke
just left click on it ...tested my end . anyone else having trouble Always listen to old people or when they die you will live on in ignorance.
Post #639385 Mon Feb 05 2024 9:04am
