Home > Faults & Fixes > Range Rover Sport EGR valves removed engine warning light
Motorman
United Kingdom 2007 Range Rover Sport 3.0 TDV6 HSE Buckingham Blue
Hi
I bought the sport with EGR valves removed and blanking plates fitted
I have a problem the engine light stays on and when reading the code P140A comes up.
Any suggestions appreciated as to solutions
Thanks
Post #639300 Thu Feb 01 2024 4:00pm
TheWojtek
While I do not think it is possible you got a 3.0 TDV6 made in 2007 - mind you, it's a 2.7 - it seems you need to map the EGR function out of the ECU. Regards etc.,
Wojtek
WAS: 2006 RRS Supercharged
IS: 2010 RRS TDV8 HSE
Post #639301 Thu Feb 01 2024 5:41pm
Motorman
Hi
Thanks for that its a 2.7 engine
I wonder if I can pick up a couple of EGR valves instead
Post #639313 Fri Feb 02 2024 9:55am
James s m
Scotland
Hi
I believe that the 2.7 tdv6 euro 3 engine from 2005 to start of 2007 could have there EGRs blacked with out putting an engine management light on but will generate fault codes ,but after the start of 2007 the euro 4 engine will put an engine management light on and definitely need mapping out to get the light off.
So yeah you can either get it mapped out or buy some new egrs and put them back in ! 2017-Discovery 5 TDV6 HSE
2007-Range Rover sport “ endless money pit “
2005-Discovery 3
Post #639316 Fri Feb 02 2024 11:13am
Motorman
Thanks for that
Had another look Looks like two blanking plates on EGR and also at the Air intake.
Pretty sure there is pipework missing to connect both together
Got another fault code coming up P1335-21 egr position sensor minimum stop performance
thanks for your help much appreciated
Post #639317 Fri Feb 02 2024 12:38pm
Pistnbroke
The information I have from Rimmer Bro (who sell the blank kit) is that 2.7 without the DPF can be blocked off without any problem.
Or take the bulb/led out of the Dash Always listen to old people or when they die you will live on in ignorance.
Post #639318 Fri Feb 02 2024 3:24pm
riverblanche
might be worth checking if the butterfly flap is still inside the intake track as well Question
when they have been blanked it could have been removed as it then removes the restriction in the air flow
(although many can not be bothered to do it Laughing )
istr the cost of the Map is about the same as 1 EGR,
personally I think the EGR's are service items and should be replaced when they fail,
the 2008 I had needed an o/s one, I got it from Maltings
Thumbs Up Porsche Cayenne 2022
gone Porsche Cayenne 2020
gone Corris Grey HSE Dynamic 2016
gone Ipanema HSE lux 2010
gone Rimini HSE 2005
Post #639560 Sat Feb 10 2024 11:07pm
